Any command to see the 'BGP Synchronization' status on Cisco rtr..?
mvsheik123
Level 7
Level 7
Hi All,
I have a 1720 rtr with IOS: 12.1(6)
It has EBGP peering with ISP rtr. No IBGP on the rtr.
BGP config:
router bgp 1111
bgp log-neighbor-changes
network 20.30.62.0 mask 255.255.255.0
network 15.5.104.0 mask 255.255.255.224
neighbor 23.23.3.17 remote-as 2222
neighbor 23.23.3.17 next-hop-self
neighbor 23.23.3.17 soft-econfiguration inbound
neighbor 23.23.3.17 route-map test out
How do I know, if BGP synchronization is enabled/desabled on this rtr. Is there any command whose o/p shows that..?
Thank you in advance
MS
PAUL TRIVINO
Level 3
Level 3
If I'm not mistaken, if you don't see "no syncronization" in the BGP config, syncronization is ON.
Paul
Istvan_Rabai
Level 7
Level 7
Hi MS,
BGP synchronization is off by default in Cisco IOS release 12.2(8)T and later.
If you don't see the "no synchronization" in the "show running-config" output, this means synchronization is set to the default value, which is "on" in your version of IOS, that is : enabled.
Cheers:
Istvan
