ANy good redistribution labs available?
hfakoor222
I want to become better at redistribution between protocols (IGP's especially , BGP)
Any good labs available, at a more advanced level? (Other than breaking apart and trying out new things on the labs I have I need some higher level labbing to understand redistribution better)
6 Replies 6
balaji.bandi
i don't think you get all one place but i have some labs while i preparing for CCIE EI ( AKA RNS)
https://www.balajibandi.com/wp-content/uploads/2022/07/CCIE-Journey-2019-v1.5.pdf
BB
thanks,
That was huge
Still ISO labs, although I may have enough maybe
Config BGP router and connect to it many routers each one run different IGP' like static eigrp and ospf.
MHM
thanks I'm looking for pre-made labs.
I'm practicing breaking down and rebuilding some of the labs I have already, so I've used up that avenue.
That bad idea' you need to build your lab' do one more steps'
What will happened if you do your lab' it not work' you  must happy with that.
If it not work then you do troubleshooting and solve issue and this make you more acknowledge in network.
Do your lab dont copy paste other lab
MHM
Blue_Bird
