any relation between cisco ISE dot1x and ssh access to NAD
mikeyasg
we have been implementing dot1x for endpoints and suddenly when ssh access to switchs were restricted endpoints started to have authentication failure. can anybody tell me how ssh to NAD and ISE dot1x are related and any idea how this issue happend?
 I bit confuse with you problem. What did you say is that a machine plugged on the switch port, lost SSH connectivity to this switch after you enabled dot1x on that port?
 You mentioned NAD and ISE which means they are not the same on your environment? Cause ISE is a NAD.
When you enable dot1x you can push dynamic acl to the interface and this could cause blocking. But I dont believe really that is the problem.
