Any way to use BGP ASN as 'source' in an ACL?
hostasaurus
Hi all, my edge routers are running IOS-XR 7.7.21.  We have quite a bit of intentionally exposed customer public address space and have endless problems with garbage traffic from a select few ASN's who don't police their networks (14061 Digital Ocean, 16276 OVH, etc.), nor respond to abuse reports.  I'm curious if anyone knows of a way to use a BGP ASN as the source in an ACL, to allow us to drop those sources for specific target ports but otherwise not affect some traffic we're forced to let through?  I can't add an ASN to an object group (which I can use in an ACL), I don't think I can use an as-path-set in an ACL, and can't use an ASN in an ACL as far as I can tell, but I obviously don't want to hand-maintain a prefix list for each ASN, nor do I want to blackhole those ASN's whether manually or via blackhole router.  I need to just block certain destination ports.
Thanks!
8 Replies 8
Can you more elaborate
MHM
Sure, I want to use BGP ASN 14061 as the source in an access list that blocks destination tcp port 21 and 22.  So, I drop port 21 and 22 in port group, and then this would take the format:
 510 deny tcp ??? any port-group PortGroupName
Now, typically one would create a net group of every ipv4 or ipv6 prefix they need, and in place of ??? you'd use "net-group NetGroupName".  I don't want to manually maintain a net group, prefix list, etc.  I want to use bgp asn 14061 (and others).  I can create an as-path-set with the ones I want, for example:
as-path-set AbusiveHosts
 originates-from '14061'
end-set
but as best I can tell, you can't use as-path-set in an ACL.  I can use it in a route policy to just drop their routes, but then I lose connectivity to these horrible ISP's, and we unfortunately have some customers who have a need to exchange email or https API interactions with customers of theirs.
So I'm at a loss on how to block just certain target tcp port traffic from certain BGP ASN's without dropping everything or having to maintain a prefix list manually.
Possibly you can use a route-map to set ToS or QoS groups based on ASNs, and then use a policy map classes to filter out the traffic you want to drop.
A follow up . . .
Just wondering whether you've considered what I suggested, or perhaps what I suggested had insufficient detail how it might work?  If the latter, let me know.
Ive never tried it but logically it might work. You can create an AS path ACL with the offending ASNs and create a separate regular ACL with the protocols needing to be dropped and then apply both of those to a route map to deny traffic which i believe is a logical AND within the same route-map. I'll try to lab it up and see if I can get some good results.
Edit to my original response:
After labbing I was able to accomplish what I believe is your goal. I made 2 lists and a route map explained below.
An EXTENDED ACL to block source/destination and ports as your intention states. I just did an IP for testing.
Extended IP access list test
10 permit ip host 1.1.1.1 any <- needs to be a permit statement to go with our route-map
An AS-Path ACL to match on ASNs as you see fit.
AS path access list 1
permit ^100$
<- this states permit anything that originated from ASN 100. This is flexible and uses REGEX so you can say anything that originates from a specific ASN, or traffic that has passed through a specific ASN, etc.
R4#sh route-map
route-map TEST, deny, sequence 10 <-first statement is a deny to deny anything that matches the criteria below
Match clauses:
ip address (access-lists): test
as-path (as-path filter): 1
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map TEST, permit, sequence 20
Match clauses:
Set clauses:
In order this route-map called TEST does the following:
DENY:the following based on being match
MATCH: Match Extended ACL AND the AS-PATH ACL <- based on my statements here is how the route-map will read:
DENY anything that matches the network in the extended ACL of test AND matches the AS-PATH ACL 1 which is anything sourced from ASN 100.
Lastly apply it inbound on the offending neighbor
neighbor 10.10.24.2 route-map TEST in
I had 2 networks coming from ASN 100. The 1.1.1.1 was blocked an the 1.1.1.11 was allowed through.
Hope this helps
-David
A better approach than what I had in mind, I believe.
I wasn't sure about match ASN(s) and ports in the same route-map statement so I had in mind matching the ASN(s) in a route-map, which would "tag" matched packets, and then a subsequent service policy would match the "tag" and an ACL, and drop such matches.
What @David Ruess proposes is more streamlined.
hostasaurus
Thanks all.  Will try this out in a few days.  I've got a new environment coming online with XR edge routers and will have the perfect opportunity to test.
Route-map use bgp as is match and filter control plane traffic
Route-map use for data traffic only match something appear in IP packet like
IP header
L4 port
And route-map using for data traffic is work with PBR' and that I think what you looking for.
What is in my mind
Match acl for traffic IP header + L4 port
Match interface <- this can use to specify for which next-hop is used for this traffic
MHM
