AnyConnect through Site to Site Where to look for packets because its not working help
Wan_Whisperer
I have a home office where a user on IP adders 10.4.4.0/24 has no Issue going through a site to site VPN accessing Site 2.s IPs like 172.21.0.0/23 and XXX.XXX.80.0/24 and all other IPs located at Site 2
now for the issue:
A user at home connected to the home office Via AnyConnect on an IP address of 10.4.4.0/24 can not access some Site 2 IPs lP 172.21.0.0/23 but can access all IPs that are not NATted.
The home office VPN is on the ASA and Site 2's VPN endpoint is on an IOS device.  I tried to use packet capture on the ASA but nothing shows up on the exit interface, I do see why it would not show up because it tunneled.   How can monitor traffic going through the VPN?    I put an ACL on two different interfaces; one interface is the one that has the crypto map on it the other interface leads to the core device.  I do not see any packets with a source or destination IP that I am trying to reach.  What is happening?
Please be detailed so I can learn from this.
Thanks for helping.
Cristian Matei
   Can you specify how devices are connected, where is the S2S tunnel terminated and where is AC terminated? Which IP's get NAT'ed and which don't?
   For example something like ROUTER(.1)----10.10.10.0/24-----(.2)ASA(.2)-----12.12.12.0/24------(.10)ROUTER
Cristian Matei.
Thanks for your reply.   I want to access 172.21.0/23 from my house using AnyConnect...
user at home.(AnyConnect VPN IP 10.4.4.221) public ip X.X.X.X----Homeoffice Termination point for AnyConnect X.X.73.59
Then
Homeoffice Site to Site (ASA origination IP X.X.73.59)------to ASR (IP X.X.0.226)
I put an ACL on "ASR (IP X.X.0.226)" and I do not see any interesting traffic.  I really did not expect to because it would be encrypted.  Then on the same device I put an ACL on the interface leading to the core, still no interesting traffic.
Just to reiterate:
Because of this I believe it something on my ASA at my home office.
Please help my Boss is getting aggravated with me.
