Anyone in the UK using CityFibre?
Steve Prescott
Is there anyone out there using CityFibre with a 1Gbps connection?
I am trying to work out what router I would need to terminate the connection (not even sure of the presentation).  The router also needs to act as a very basic firewall and support NetFlow.  I am looking at two 1Gbps LAN ports, one will trunk VLANs and the other will be used for sending NetFlow data. So I will need a WIC of some description for the WAN connection?
Any help/guidance whatsoever would be truly appreciated.
Thanks in advance.
saif musa
Level 4
Level 4
Steve,
Chick this tool from cisco, it maybe helps..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Please rate if its helpful
Saif,
Thanks for the reply, really useful tool - I've added it to my bookmarks.
Unfortunately it doesn't help me with this particular problem as I don't know what CityFibre actually provide.
