AP 3602 is disconnected from WLC
gerardohvv
This ap is disconnected from the WLC lately, he's doing more often.
someone has something similar happened?
*Jun 27 17:54:45.159: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 2)
*Jun 27 17:54:51.203: %EVT-4-WRN: Write of flash:/event.capwap done
*Jun 27 17:54:51.227: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Jun 27 17:54:51.231: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jun 27 17:54:51.231: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.101.0.200:5246
*Jun 27 17:54:51.231: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established. 10.101.0.200, 147E, 10.104.0.219, 77B3, 0
*Jun 27 17:54:51.299: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Jun 27 17:54:51.303: %CLEANAIR-6-STATE: Slot 0 down
*Jun 27 17:54:51.303: %CLEANAIR-6-STATE: Slot 1 down
*Jun 27 17:54:54.735: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jun 27 17:55:05.703: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jun 27 17:55:09.303: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.interceramic.com
*Jun 27 17:55:16.571: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jun 27 17:55:19.303: %CAPWAP-3-ERRORLOG: Selected MWAR 'InterceramicWLC'(index 0).
*Jun 27 17:55:19.303: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jun 27 17:55:09.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.101.0.200 peer_port: 5246
*Jun 27 17:55:09.575: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.101.0.200 peer_port: 5246
*Jun 27 17:55:09.579: %CAPWAP-5-SENDJOIN: sending Join Request to 10.101.0.200
*Jun 27 17:55:09.595: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jun 27 17:55:09.595: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jun 27 17:55:09.595: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jun 27 17:55:09.595: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.101.0.200
*Jun 27 17:55:10.391: Starting Ethernet promiscuous mode
*Jun 27 17:55:10.775: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Jun 27 17:55:11.083: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller InterceramicWLC
*Jun 27 17:55:11.131: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jun 27 17:55:11.135: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jun 27 17:55:11.135: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jun 27 17:55:11.135: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration fileWLAN id 1, SSID u5u4r105, L2ACL , L2ACL AP
WLAN id 10, SSID r0du((10))p, L2ACL , L2ACL AP
WLAN id 2, SSID 6u3575, L2ACL , L2ACL AP
WLAN id 3, SSID d1r3((10N)), L2ACL , L2ACL AP
WLAN id 4, SSID 4dm1n157r4(10n, L2ACL , L2ACL AP
WLAN id 5, SSID t)@b!3T(@5, L2ACL , L2ACL AP
WLAN id 6, SSID e3fB8L31Jt, L2ACL , L2ACL AP
WLAN id 7, SSID p1570L45d, L2ACL , L2ACL AP
WLAN id 8, SSID 58rvR3@pw!, L2ACL , L2ACL AP
WLAN id 9, SSID n1,#B3R$3r@W!q, L2ACL , L2ACL AP
*Jun 27 17:55:11.135: %LWAPP-3-CLIENTERRORLOG: Switching to Connected mode
*Jun 27 17:55:54.127: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Jun 27 17:55:57.771:  Certificate import is not completed yet, so not deleting the trustpoint
*Jun 27 17:56:39.271: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 27 17:56:41.331: %CLEANAIR-6-STATE: Slot 1 enabled
*Jun 27 18:56:00.603: 60be.b5f0.3cab-no legacy rates; default to lowest CCK/OFDM rate
*Jun 27 18:56:00.811: ac3c.0bec.a169-no legacy rates; default to lowest CCK/OFDM rate
*Jun 27 18:56:09.615: c0cb.3811.52f4-no legacy rates; default to lowest CCK/OFDM rate
*Jun 28 09:21:12.379: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 28 09:21:12.471: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 28 09:21:13.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 28 09:21:13.419: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 28 09:21:14.419: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 28 09:21:33.075: %CLEANAIR-6-STATE: Slot 0 down
*Jun 28 09:21:50.163: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 28 12:55:34.171: %WIDS-4-SIG_ALARM: Attack is detected on Sig:Standard Id:5 Channel:1 Source MAC:4859.29a1.ef2c
*Jun 28 13:15:34.987: %WIDS-6-SIG_ALARM_OFF: Attack is cleared on Sig:Standard Id:5 Channel:1
*Jun 28 23:04:58.399: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 28 23:04:58.491: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 28 23:04:59.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 28 23:04:59.439: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 28 23:05:00.439: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 28 23:05:15.535: %CLEANAIR-6-STATE: Slot 0 down
*Jun 28 23:05:32.379: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 29 02:18:14.903: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 29 02:18:15.123: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 29 02:18:15.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 29 02:18:15.943: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 29 02:18:16.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 29 02:18:32.459: %CLEANAIR-6-STATE: Slot 0 down
*Jun 29 02:18:49.907: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 29 05:31:39.339: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 29 05:31:39.423: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 29 05:31:40.355: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 29 05:31:40.383: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 29 05:31:41.383: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 29 05:32:00.631: %CLEANAIR-6-STATE: Slot 0 down
*Jun 29 05:32:17.411: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 29 10:46:56.275: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 29 10:46:56.567: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 29 10:46:57.275: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 29 10:46:57.519: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 29 10:46:58.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 29 10:47:17.511: %CLEANAIR-6-STATE: Slot 0 down
*Jun 29 10:47:34.287: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 30 09:50:00.819: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 30 09:50:00.827: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 30 09:50:01.835: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 30 09:50:01.859: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 30 09:50:02.859: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 30 09:50:21.751: %CLEANAIR-6-STATE: Slot 0 down
*Jun 30 09:50:38.691: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 30 14:25:06.259: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 30 14:25:06.347: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 30 14:25:07.275: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 30 14:25:07.299: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 30 14:25:08.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 30 14:25:23.847: %CLEANAIR-6-STATE: Slot 0 down
*Jun 30 14:25:40.623: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 30 14:45:26.663: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 30 14:45:26.751: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 30 14:45:27.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 30 14:45:27.707: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 30 14:45:28.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 30 14:45:45.635: %CLEANAIR-6-STATE: Slot 0 down
*Jun 30 14:46:02.415: %CLEANAIR-6-STATE: Slot 0 enabled
*Jun 30 16:57:38.759: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jun 30 16:57:38.959: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun 30 16:57:39.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jun 30 16:57:39.799: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 30 16:57:40.799: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jun 30 16:57:57.003: %CLEANAIR-6-STATE: Slot 0 down
*Jun 30 16:58:14.351: %CLEANAIR-6-STATE: Slot 0 enabled
*Jul  1 14:42:26.991: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 3)
*Jul  1 14:42:33.279: %EVT-4-WRN: Write of flash:/event.capwap done
*Jul  1 14:42:33.299: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Jul  1 14:42:33.303: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jul  1 14:42:33.303: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.101.0.200:5246
*Jul  1 14:42:33.371: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Jul  1 14:42:33.375: %CLEANAIR-6-STATE: Slot 0 down
*Jul  1 14:42:33.375: %CLEANAIR-6-STATE: Slot 1 down
*Jul  1 14:42:33.495: %RADIUS-3-NOSERVERS: No Radius hosts configured or no valid server present in the server group radius
*Jul  1 14:42:33.495: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:42:38.775: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d94 Authentication failed
*Jul  1 14:42:45.579: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:42:51.367: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d94 Authentication failed
*Jul  1 14:42:51.375: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.interceramic.com
*Jul  1 14:42:58.239: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:43:01.375: %CAPWAP-3-ERRORLOG: Selected MWAR 'InterceramicWLC'(index 0).
*Jul  1 14:43:01.375: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul  1 14:42:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.101.0.200 peer_port: 5246
*Jul  1 14:42:53.127: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:42:58.215: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:43:04.183: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:43:10.251: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:43:19.715: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:43:21.131: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2176 Max retransmission count reached!
*Jul  1 14:43:25.907: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:43:32.259: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:43:38.531: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:43:45.215: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:43:50.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.101.0.200:5246
*Jul  1 14:43:51.487: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:43:58.175: %DOT11-7-AUTH_FAILED: Station 68a8.6d4e.363e Authentication failed
*Jul  1 14:44:04.823: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:44:09.047: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.interceramic.com
*Jul  1 14:44:11.063: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:44:17.303: %DOT11-7-AUTH_FAILED: Station c0cb.3811.52f4 Authentication failed
*Jul  1 14:44:19.047: %CAPWAP-3-ERRORLOG: Selected MWAR 'InterceramicWLC'(index 0).
*Jul  1 14:44:19.047: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul  1 14:44:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.101.0.200 peer_port: 5246
*Jul  1 14:44:26.355: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:44:41.795: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:44:49.143: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2176 Max retransmission count reached!
*Jul  1 14:44:52.659: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:45:00.647: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:45:09.035: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:45:14.387: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:45:18.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.101.0.200:5246
*Jul  1 14:45:25.251: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:45:33.839: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:45:37.047: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.interceramic.com
*Jul  1 14:45:41.795: %DOT11-7-AUTH_FAILED: Station 446d.57b3.0d99 Authentication failed
*Jul  1 14:45:46.975: %DOT11-7-AUTH_FAILED: Station c473.1e14.e15a Authentication failed
*Jul  1 14:45:47.047: %CAPWAP-3-ERRORLOG: Selected MWAR 'InterceramicWLC'(index 0).
*Jul  1 14:45:47.047: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul  1 14:45:47.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.101.0.200 peer_port: 5246
*Jul  1 14:45:47.503: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.101.0.200 peer_port: 5246
*Jul  1 14:45:47.503: %CAPWAP-5-SENDJOIN: sending Join Request to 10.101.0.200
*Jul  1 14:45:47.519: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jul  1 14:45:47.519: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jul  1 14:45:47.519: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jul  1 14:45:47.519: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.101.0.200
*Jul  1 14:45:47.615: Starting Ethernet promiscuous mode
*Jul  1 14:45:47.995: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Jul  1 14:45:48.747: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller InterceramicWLC
*Jul  1 14:45:48.795: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jul  1 14:45:48.795: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jul  1 14:45:48.795: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration fileWLAN id 1, SSID u5u4r105, L2ACL , L2ACL AP
*Jul  1 14:45:48.795: %LWAPP-3-CLIENTERRORLOG: Switching to Connected mode
*Jul  1 14:46:24.287: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Jul  1 14:46:24.615:  Certificate import is not completed yet, so not deleting the trustpoint
capwap_central_auth_info_add_mn: Invalid client mac address 446d.57b3.0d99
*Jul  1 14:46:53.355: %CLEANAIR-6-STATE: Slot 0 enabled
*Jul  1 14:46:55.415: %CLEANAIR-6-STATE: Slot 1 enabled
ap_ITP4#Connection to 10.104.0.219 closed by remote host.
Leo Laohoo
Can you check the AP's uptime every time it re-joins the controller?
What firmware is the WLC running on?
hi Leo.
I attached the screen.
hi leo,
this is log now.
*Jul  2 23:57:01.427: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 6)
*Jul  2 23:57:01.431: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Jul  2 23:57:01.435: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jul  2 23:57:01.435: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.101.0.200:5246
*Jul  2 23:57:01.499: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Jul  2 23:57:01.503: %CLEANAIR-6-STATE: Slot 0 down
*Jul  2 23:57:01.503: %CLEANAIR-6-STATE: Slot 1 down
*Jul  2 23:57:11.579: %CAPWAP-3-ERRORLOG: Selected MWAR 'InterceramicWLC'(index 0).
*Jul  2 23:57:11.579: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul  2 23:57:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.101.0.200 peer_port: 5246
*Jul  2 23:57:02.663: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.101.0.200 peer_port: 5246
*Jul  2 23:57:02.663: %CAPWAP-5-SENDJOIN: sending Join Request to 10.101.0.200
*Jul  2 23:57:02.683: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jul  2 23:57:02.683: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jul  2 23:57:02.683: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jul  2 23:57:02.683: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.101.0.200
*Jul  2 23:57:03.223: Starting Ethernet promiscuous mode
*Jul  2 23:57:03.675: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Jul  2 23:57:03.979: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller InterceramicWLC
*Jul  2 23:57:04.027: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jul  2 23:57:04.027: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Jul  2 23:57:04.027: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration fileWLAN id 1, SSID u5u4r105, L2ACL , L2ACL AP
*Jul  2 23:57:04.031: %LWAPP-3-CLIENTERRORLOG: Switching to Connected mode
*Jul  2 23:57:16.955: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Jul  2 23:57:20.851:  Certificate import is not completed yet, so not deleting the trustpoint
capwap_central_auth_info_add_mn: Invalid client mac address 60be.b5f8.9719
*Jul  2 23:57:48.139: %CLEANAIR-6-STATE: Slot 0 enabled
*Jul  2 23:57:50.199: %CLEANAIR-6-STATE: Slot 1 enabledcapwap_central_auth_info_add_mn: Invalid client mac address c0cb.3811.52f4
capwap_central_auth_info_add_mn: Invalid client mac address 446d.57b3.0d94
gracias
