C7609 same mac-address on all interfaces
Calin C.
Level 5
Level 5
Hello!
On of my friends has a problem with a C7609. On all interfaces there is the same mac-address (see below). Do you know why this is happening?
Thanks!
FastEthernet4/1/1 is up, line protocol is up
Hardware is i82543 FastEthernet Interface, address is 001b.0de5.e540 (bia 001b.0de5.e540)
Description: WCDMA SUA Sigtran B
Internet address is 10.207.29.246/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:01, output 00:00:00, output hang never
Input queue: 0/200/0/0 (size/max/drops/flushes); Total output drops: 182446
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2292 packets input, 141335 bytes, 0 no buffer
Received 48 broadcasts (0 IP multicasts)
0 watchdog
3487 packets output, 209543 bytes, 0 underruns
8 output errors, 0 collisions, 3 interface resets
5 lost carrier, 0 no carrier
GigabitEthernet5/1 is administratively down, line protocol is down (disabled)
Hardware is C6k 1000Mb 802.3, address is 001b.0de5.e540 (bia 001b.0de5.e540)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
GigabitEthernet5/2 is administratively down, line protocol is down (disabled)
Description: Management Access
Media-type configured as SFP connector
Clock mode is auto
royalblues
Level 10
Level 10
By default, Catalyst switches come with the same MAC address configured on all interfaces.
This is not a problem. Try removing the ip address from the interface and make it an L2 port. you should see that the mac-address chnages
Narayan
Could you please explain me how to do it by commands
I faced the same situation in the past & I've set manually new MAC addresses for the interfaces that I want to use (I've add +1 from the Built in mac address)
Tarik
Tarik,
Actually the way you adopted is the right one cos it may not be feasibel for you to chnage a L3 port to L2 port based on your topology
In terms of commands, its just turning an L3 port to L2 for eg.
interface fa 0/1
no ip addres
switchport
Have a look here
https://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c9b4e.shtml
Narayan
Lalit Agrawal
Please correct me if I am wrong, but cisco 7609 is a router not a catalyst switch.
I faced an issue where two of my router ports(Gig7/0/0 and Gig8/0/0) are connected to switch ports(Gi1/0/26 and Gi1/0/27) respectively.
Multiple dot1q sub-interfaces are configured on the router ports.
Due to some misconfiguration same vlan 10 is assigned to sub-interfaces gig7/0/0.10 and gig8/0/0.10, which lead to continuous macflap for vlan 10 on switch.
This macflap lead to bgp session flap which created a havoc in the network.
2xGE V2 SPA cards are inserted in module 7 and module 8.
Router#sh arp vrf abc
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.108.144.217          -   0027.0dfd.2840  ARPA   GigabitEthernet7/0/0.10
Internet  10.108.144.218        150   0015.2c27.5d04  ARPA   GigabitEthernet7/0/0.10
Router#
Router#sh arp vrf xyz
Internet  10.108.145.5            -   0027.0dfd.2840  ARPA   GigabitEthernet8/0/0.10
Internet  10.108.145.6          174   04fe.7f91.9911  ARPA   GigabitEthernet8/0/0.10
Router#
Switch#sh log | i 10
Jul  2 10:35:06.177 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 10:41:39.864 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 11:46:37.377 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 11:59:04.436 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/27 and port Gi1/0/26
Jul  2 12:09:10.137 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 12:49:31.744 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 13:51:23.690 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Jul  2 14:17:19.690 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/27 and port Gi1/0/26
Jul  2 14:35:58.743 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0027.0dfd.2840 in vlan 10 is flapping between port Gi1/0/26 and port Gi1/0/27
Why the physical interface on the router does not have unique mac address ?
