Application Interface Running Slow on MPLS
nasdaq123
Evening All,
We have an MPLS Core Which has connection to 3 sites and a Datacentre. the datacentre is where the Database Server sits for this application Database which uses Interbase XE7, this a Borland Database which is SQL92 compliant, the application seems to work fine from Monday to Tuesday but from Wednesday onwards as there is more data going across to the database server, the transmission starts to slow down from clients to server with connection to the databse dropping on some of the clients at times. The network 1GB bandwidth over 1GB bearer line, this was the requirement from the supplier.. Our MPLS uses BGP protocol to route traffic.
We have done everything possible on the network but we cannot see any issues with the network. could it be  that the database has limitations with BGP routing. We did a wireshark trace as well and noticed that the DB was refusing incoming connections when it was very busy. is there anything else we can do on the network to stop the slowness and the dropouts. we had discussed the idea of keep alive with the suppliers but they cannot do that.
On a Gig interface, 500-600Mb of traffic is not bad at all and so there is enough bandwidth for the DB to use. I think the issue is application related and not so much the switch or the LAN environment.
5 Replies 5
Reza Sharifi
Do you any QOS deployed anywhere on the path?
If you did a Wireshark and the DB is refusing connection then that is a limitation on the data base.
When the network is busy and this happens, what is the amount of traffic on the 1Gig link?
There is Qos on the network as it might impact the other services, what we have done on the Local LAN is to create VLANs, Thsi Interface has it's own VLAN which connect to the Database server at the Datacentre
The max amount of the traffic is usually around 500-600MB and the latency is 3ms
Yemi
in addition to Reza's suggestions, you also might want to check MTU settings (MPLS is usually higher than the standard 1500).
Can you post the running config of the router facing the MPLS core ?
Sorry have been busy, please see the routers both the core and site as requested
 CE WAN port
GigabitEthernet0/0/1 is up, line protocol is up
  Hardware is ISR4431-X-4x1GE, address is d8b1.90eb.9051 (bia d8b1.90eb.9051)
  Description: ***CEW009274 - Fibre WAN Link - 1Gb/1Gb******
  Internet address is 172.18.1.2/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 6/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is SX
  output flow-control is off, input flow-control is off
  Last input 01:03:38, output 00:00:35, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute input rate 25673000 bits/sec, 4179 packets/sec
  5 minute output rate 4658000 bits/sec, 3086 packets/sec
     3518513005 packets input, 2567544396268 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     2654766208 packets output, 542848336049 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Protocol status
#show ip int br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   unassigned      YES NVRAM  up                    up
GigabitEthernet0/0/0.1 172.18.6.3      YES NVRAM  up                    up
Gi0/0/0.10             192.168.110.1   YES NVRAM  up                    up
Gi0/0/0.99             192.168.113.1   YES NVRAM  up                    up
Gi0/0/0.100            192.168.111.1   YES NVRAM  up                    up
Gi0/0/0.110            192.168.112.1   YES NVRAM  up                    up
Gi0/0/0.130            192.168.114.1   YES NVRAM  up                    up
Gi0/0/0.140            192.168.115.1   YES NVRAM  up                    up
GigabitEthernet0/0/1   172.18.1.2      YES NVRAM  up                    up
GigabitEthernet0/0/2   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/3   unassigned      YES NVRAM  administratively down down
ATM0/1/0               unassigned      YES NVRAM  up                    up
ATM0/1/0.38            unassigned      YES unset  up                    up
Ethernet0/1/0          unassigned      YES NVRAM  down                  down
GigabitEthernet0       unassigned      YES NVRAM  administratively down down
Dialer1                109.176.112.146 YES IPCP   up                    up
Loopback0              109.176.109.6   YES NVRAM  up                    up
Virtual-Access1        unassigned      YES unset  up                    up
Virtual-Access2        unassigned      YES NVRAM  up                    up
Local Lan interface
show int gig 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is ISR4431-X-4x1GE, address is d8b1.90eb.9050 (bia d8b1.90eb.9050)
     reliability 255/255, txload 6/255, rxload 1/255
  Full Duplex, 1000Mbps, link type is auto, media type is RJ45
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  5 minute input rate 4687000 bits/sec, 3026 packets/sec
  5 minute output rate 24173000 bits/sec, 4029 packets/sec
     2730013692 packets input, 563427876638 bytes, 0 no buffer
     Received 19612368 broadcasts (0 IP multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 12984701 multicast, 0 pause input
     3570759117 packets output, 2587530711568 bytes, 0 underruns
     141955 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
     0 output buffer failures, 0 output buffers swapped out EMR00620A#
And Core router port.
RP/0/RSP0/CPU0:lon-th1eagw#show running interface TenGigE0/0/0/0.2601 Wed Jun 14 12:50:56.080 BST interface TenGigE0/0/0/0.2601  description ***IPP EMR00620A***  vrf EC_IPP
 ipv4 address 172.18.1.1 255.255.255.252  load-interval 30  encapsulation dot1q 2601 !
RP/0/RSP0/CPU0:lon-th1eagw#show int TenGigE0/0/0/0.2601 Wed Jun 14 12:51:34.202 BST
TenGigE0/0/0/0.2601 is up, line protocol is up
  Interface state transitions: 1
  Hardware is VLAN sub-interface(s), address is d867.d933.198e
  Description: ***IPP EMR00620A***
  Internet address is 172.18.1.1/30
  MTU 2004 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation 802.1Q Virtual LAN, VLAN Id 2601,  loopback not set,
  Last link flapped 30w2d
  ARP type ARPA, ARP timeout 04:00:00
  30 second input rate 4019000 bits/sec, 2911 packets/sec
  30 second output rate 21770000 bits/sec, 3647 packets/sec
     19094274569 packets input, 4661561168594 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 21 broadcast packets, 339493 multicast packets
     23011016992 packets output, 15776326087362 bytes, 0 total output drops
     Output 2 broadcast packets, 0 multicast packets
