Issue with setting up WAAS on ISR 4331
Quintin.Mayo
Level 3
Level 3
We have a cisco 4331 router that will not allow us to enable and configure the WAAS service.
We receive the following error after running through the “service waas enable”:
“installation failure decision to exit”
It appear to be failing because the router does not appear to be recognizing commands:
VirtualPortGroup31
Or
virtual-service AUTOWAAS
Not sure if this is a licensing issue or something that needs enabled?
Reza Sharifi
See table-4 in this link:
Do you have the correct software license, memory, etc..
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/guide_c07-726864.html
