Apply PBR on sub-interface
Hi all ,
I have cisco NCS-5001 ,, i tried to apply PBR on the sub-interface , but i can't do that's as you can see below .. So any advice or alternative method to apply it .. Thanks in advance
ipv4 access-list Test
10 permit ipv4 any any
class-map type traffic match-any Test
match access-group ipv4 Test
end-class-map
policy-map type pbr Test
class type traffic Test
redirect ipv4 nexthop 10.1.10.1
class type traffic class-default
transmit
end-policy-map
RP/0/RP0/CPU0:NCS(config)#interface FortyGigE0/0/1/0.153
RP/0/RP0/CPU0:NCS(config-subif)#service-policy type ?
% Invalid input detected at '^' marker.
8 Replies 8
Mark Malone
i dont have these specific models to exactly confirm but when i look at the data sheet PBR is not listed as supported
Usually its listed and if doesnt take its a license issue but i dont even see it listed , is it taking on physial interface ?
Sometimes the syntax can be there but not allowed to be applied if unsupported
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5000-series/datasheet-c78-736153.html
This looks like maybe another method for XR
https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5000/routing/63x/b-routing-cg-ncs5000-63x/b-routing-cg-ncs5000-63x_chapter_0110.html
maybe config guides show something but i couldnt see any PBR ther either
Yes is the same issue with the physical interface .. Thanks
it works on the ASR9000, I suspect it doesn't on the NCS5001.I don't get that specific command to run either on the CSR1000...
yes dont think your going to get it working then , it looks as if its not supported , definitely if it cant be applied to physical main interface
So , is there any alternative method to apply the command for set ip next-hop ?  Thanks in advance
would 'standard' (as opposed to enhanced) PBR be an option ?
By the way, FYI, I attach the link with regard to ePBR on the ASR9K, which mirrors what you want to do. I have been looking around, a lot, but there is sparse information around at best specifically for the NCS5001...
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/addr-serv/configuration/guide/b-asr9000-ip-addresses-configuration-guide-61x/b-asr9000-ip-addresses-configuration-guide-61x_chapter_01111.html#id_60466
Hello
why are you trying to policy route when your access-list is defining all traffic why not just use a default static route?
Kind Regards
Paul
This was just for test ..  the main goal to catch the HTTP traffic ( i.e L4 traffic ) and set IP next-hop .. Therefor i need PBR ..
