Apply QoS LLQ to Cisco 1721 ADSL interface issue
kevintang
I can not apply the LLQ to ADSL ATM interface. the system take the command with out any error message, but no in the show running config. Any idea or Cisco link can explain this?
class-map match-all control
match dscp af31
class-map match-all voice
match dscp ef
policy-map wan-out
class voice
priority 256
class control
bandwidth remaining percent 20
class class-default
fair-queue
policy-map wan-shap
class class-default
shape average 512000
service-policy wan-out
interface ATM0
bandwidth 512
no ip address
logging event subif-link-status
load-interval 30
no atm ilmi-keepalive
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex B
dsl linerate AUTO
interface ATM0.102 point-to-point
mtu 1500
bandwidth 512
ip address 172.18.43.110 255.255.255.254
ip split-horizon
no snmp trap link-status
pvc 0/102
oam-pvc manage 5
encapsulation aal5snap
IP3AK1-B21#conf t
Enter configuration commands, one per line. End with CNTL/Z.
IP3AK1-B21(config)#int atm0.102
IP3AK1-B21(config-subif)#pvc 0/102
IP3AK1-B21(config-if-atm-vc)#service out wan-shap
IP3AK1-B21(config-if-atm-vc)#exit
IP3AK1-B21(config-subif)#exit
IP3AK1-B21(config)#exit
IP3AK1-B21#sh run int atm0.102
Building configuration...
Current configuration : 211 bytes
mtu 1500
bandwidth 512
ip split-horizon
pvc 0/102
oam-pvc manage 5
end
IP3AK1-B21#
mohammedmahmoud
Level 11
Level 11
Hi there,
Have you tried to configure the service-policy under the sub-interface rather than the PVC ?
BR,
Mohammed Mahmoud.
I have the same problem.
Cisco 800 series accepts the command either in main interface or sub-interface. But after doing sho run, its not there.....
any comments?
