Applying policy-map to two interfaces
brian.agbalenyo
Am applying a policy map to
  1. gig0/0
  2. interface vlan x
If i apply to either one only it is ok but if i apply it to the other interface it says ''configuration fail''.
Am not also given the option to apply it to a particular interface as the one below
service-policy  QoS_policy interface inside
Routers 1921
             2801
Any help with this please?
Abzal
Level 7
Level 7
You might've typed wrong command
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfmcli2.html#wp1021794
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
There might be something wrong with policy map configuration.  Do Post policy map configuration.
*** Rate All Helpful Posts***
Jawad
