Arbor TMS in ASR9000/VSM
haitham.jneid
Hi Experts,
I am planning to to deploy Arbor on ASR9000 using VSM card. I need some documents/references which explaining the solution and deployment requirements/procedures.
thanks,
Haitham Jneid
https://supportforums.cisco.com/document/12449061/arbor-peakflow-ddos-mitigation-asr-9000-vsm
https://supportforums.cisco.com/document/12885281/installation-steps-arbor-tms-asr9000vsm
http://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/solution-overview-c22-736143.html
https://www.arbornetworks.com/images/documents/Data%20Sheets/DS_TMS_EN.pdf
https://www.arbornetworks.com/images/PB_CiscoASR9000_EN2015.pdf
Hi Jonathan,
Thank you for your support, I have already went through these links, so far, I understand the solution and I know how to add a VSM card and bring it online, but I need to know the following:
- BGP configuration between VSM TMS and ASR9000
- BGP configuration between Collector and ASR9000
- Peakflow SP is virtualized, do we have to create one VM for the collector and one VM for the controller? or one image will play both roles.
- Do we have to use BGP flowspec or Netflow and what is the difference?
- How to pair VSM TMS with the Peakflow SP collector / Controller?
- Any specific document to guide us about all required steps/configuration between Peakflow SP collector/controller and VSM TMS?
thanks,
Haitham Jneid
Have you reached out to TAC at all?
Both the ASR9k and the Arbor solution are considered service provider (SP) / carrier class solutions.  You may have some luck posting in the SP space, although I'm guessing if you have either of these products, you probably have ready access, at a very high SLA, to TAC as well.
