OSPF between WS-C3850 and ASR1001-X
julomban1
Hello Everyone,
Between the 3850 and ASR we have some vlans configured, all with OSPF enabled.
There is a main/prefer vlan that goes through another set of routers, one of those routers went down and OSPF also went down. This affected OSPF between the 3850 and ASR and all vlans went down or lost communication.
OSPF is configured with router id since in the IOS is require and even though I have loopbacks they didn't work to keep the session up.
How can I fix or improve this?
Juan
Julio E. Moisa
Hi Juan,
Please correct me if I understanding wrong, but you want to establish OSPF adjacency using loopbacks?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Not really but now that you mentioned it could be a solution, using the loopbacks.
The OSPF adjacency cannot be make using loopbacks, like in BGP.
Do you have a topology how the vlans are being implemented or  passing through.
