Are PAT and NAT compatible on one interface?
Ron Michaels
I am currently using a PAT overload statement to get public addresses on internet traffic.
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.140.0.1 255.255.254.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.3
description Outside Interface
encapsulation dot1Q 3
ip address 64.22.229.210 255.255.255.248
ip access-group inbound_reflexive_fw_acl in
ip access-group outbound_reflexive_fw_acl out
ip flow ingress
ip flow egress
ip nat outside
no cdp enable
crypto map Tunnel_to_MarkIV
ip nat inside source list No_Nat_ACL interface GigabitEthernet0/0.3 overload
But now they also want to NAT one address for the video conference unit 10.140.0.8 to 64.22.229.214.
When I put in a static NAT line - ip nat inside source static 10.140.0.8 64.22.229.214
I still can't get out to the internet for a video conference.
Peter Paluch
Hi Ron,
Using PAT and NAT like you did should be supported and should work. A couple of questions and hints:
  1. Why is the ACL used for NAT called No_Nat_ACL? What are the contents of this ACL? Please post it here.
  2. Check the show ip nat translation output to see if the 10.140.0.8 is correctly mapped to 64.22.229.214. I also suggest adding the IP address 10.140.0.8 to the ACL No_Nat_ACL with a deny action (i.e. a static mapping should be excluded from dynamic mapping)
  3. Do the ACLs inbound_reflexive_fw_acl and outbound_reflexive_fw_acl correctly permit the video traffic?
Best regards,
Peter
Peter,
Thanks for you help.  The No_Nat_ACL is where I have all of my deny statements for traffic inside our company and then an allow to NAT the rest. This is where I used your tip to deny the static NAT and it was working.
I already allowed traffic from the internet to this public address that then gets NATed to the private address.
Thanks again,
Ron
Hi Ron,
So adding the static translation as a deny statement to the ACL helped?
By the way, I hope the No_Nat_ACL does not have a permit ip any any at its end. This would be a configuration that is claimed as unsupported by Cisco. Can you perhaps post the ACL here?
Best regards,
Peter
