port error
saquib.tandel
Hello
ISP provided Internet link over a Wimax Device. The switchport on which the wimax is terminated keeps changing from Orange to Green.
Initially we kept speed and duplex auto but no luck then we changed as per wimax team informed to speed 10 duplex full but still the same issue
config on port
interface GigabitEthernet0/48
description WIMAX_IN_881
switchport access vlan 5
switchport mode access
speed 10
duplex full
kindly input to overcome this
thanks
ST
5 Replies 5
Sandeep Choudhary
HI Saquib,
Try with
speed auto
duplex auto/Full
let me know the results.
Please rate if iot helps.
Hi Sandeep
Thanks for replying, if you see the original post I already mentioned testing speed auto / duplex auto didnt help
troubleshooting also included duplex full but no luck
Not sure what more to look out
thanks
ST
Hi Saquib,
Have you try with speed auto, duplex full?
if still not working then call to your ISP provider and tell them to open the port from there side.
Please rate if it helps.
Hi Sandeep
What you mean by open the port from ISP end.
WIMAX device is installed on the Top of the building and a UTP cable is drop to the datacenter.
1. check UTP cable., if its ok then contact ISP.
Means check the setting of device from ISP end.
They only can resolve the issue.
