Area BACKBONE(0) (Inactive)
dkingfx00
Hi all,
i'm new to this Cisco world so bare with me please. i'm trying to configure OSPF between two Cisco 2800 series and i'm unable to see the neighbor routers. the design is not fully completed since i'm waiting for my second ASA and ISP link but i'm trying to get as much done and configure both routers. i had bgp configured and working but removed it to try to isolate the issue. i will be adding it back.
here is brief of the topology i have and will be implementing. see attachment for a more detail drawing.
Thanks in advance for the help.
ISP1[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[-Future ISP2
ASA 5505[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[Future ASA 5505
R1<--------crossover cable------------->R2
Switch1[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[switch2
R2 config
interface GigabitEthernet0/0
 description INSIDE LAN SWHC-XX
 ip address 172.16.0.2 255.255.255.0
 ip helper-address 172.16.0.20
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description CONNECTION TO R1 Gi0/1 CROSSOVER CABLE
 ip address 172.16.1.2 255.255.255.252
 duplex auto
 speed auto
router ospf 1
 router-id 172.16.0.2
 log-adjacency-changes
 redistribute connected
 passive-interface default
 network 172.16.0.0 0.0.0.255 area 0
 network 172.16.1.0 0.0.0.3 area 0
OSPF output
R2#sh ip os
R2#sh ip ospf
 Routing Process "ospf 1" with ID 172.16.0.2
 Start time: 00:00:42.372, Time elapsed: 03:40:02.148
 Supports only single TOS(TOS0) routes
 Supports opaque LSA
 Supports Link-local Signaling (LLS)
 Supports area transit capability
 It is an autonomous system boundary router
 Redistributing External Routes from,
    connected
 Router is not originating router-LSAs with maximum metric
 Initial SPF schedule delay 5000 msecs
 Minimum hold time between two consecutive SPFs 10000 msecs
 Maximum wait time between two consecutive SPFs 10000 msecs
 Incremental-SPF disabled
 Minimum LSA interval 5 secs
 Minimum LSA arrival 1000 msecs
 LSA group pacing timer 240 secs
 Interface flood pacing timer 33 msecs
 Retransmission pacing timer 66 msecs
 Number of external LSA 0. Checksum Sum 0x000000
 Number of opaque AS LSA 0. Checksum Sum 0x000000
 Number of DCbitless external and opaque AS LSA 0
 Number of DoNotAge external and opaque AS LSA 0
 Number of areas in this router is 1. 1 normal 0 stub 0 nssa
 Number of areas transit capable is 0
 External flood list length 0
 IETF NSF helper support enabled
 Cisco NSF helper support enabled
        Number of interfaces in this area is 2
        Area has no authentication
        SPF algorithm last executed 00:22:56.056 ago
        SPF algorithm executed 3 times
        Area ranges are
        Number of LSA 1. Checksum Sum 0x007AAC
        Number of opaque link LSA 0. Checksum Sum 0x000000
        Number of DCbitless LSA 0
        Number of indication LSA 0
        Number of DoNotAge LSA 0
        Flood list length 0
R1 config
 description INSIDE LAN SWITCH SWHC-1
 ip address 172.16.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/0.20
 description Offices VLAN
 encapsulation dot1Q 20
 ip address 172.17.0.2 255.255.255.0
 standby 20 ip 172.17.0.1
 standby 20 priority 110
 standby 20 preempt
interface GigabitEthernet0/0.30
 description Dev Team VLAN
 encapsulation dot1Q 30
 ip address 172.18.0.2 255.255.255.0
 standby 30 ip 172.18.0.1
 standby 30 priority 110
 standby 30 preempt
interface GigabitEthernet0/0.40
 description Private Wireless VLAN
 encapsulation dot1Q 40
 ip address 172.19.0.2 255.255.255.0
 standby 40 ip 172.19.0.1
 standby 40 priority 110
 standby 40 preempt
interface GigabitEthernet0/0.50
 description Public Wireless VLAN
 encapsulation dot1Q 50
 ip address 172.20.0.2 255.255.255.0
 standby 50 ip 172.20.0.1
 standby 50 priority 110
 standby 50 preempt
 description CONNECTION TO R2 Gi0/1 CROSSOVER CABLE
 ip address 172.16.1.1 255.255.255.252
 duplex auto
 speed auto
interface FastEthernet0/2/0
 description TO ASA Firewall Eth0/1
 ip address 172.15.0.2 255.255.255.252
 ip access-group 1 out
 duplex auto
 speed auto
router ospf 1
 router-id 172.16.0.1
 no passive-interface FastEthernet0/2/0
 network 172.15.0.0 0.0.0.3 area 0
 network 172.17.0.0 0.0.0.255 area 0
 network 172.18.0.0 0.0.0.255 area 0
 network 172.19.0.0 0.0.0.255 area 0
 network 172.20.0.0 0.0.0.255 area 0
 default-information originate
ospf output
R1#sh ip ospf
R1#sh ip ospf
 Routing Process "ospf 1" with ID 172.16.0.1
 Start time: 00:00:47.364, Time elapsed: 4d05h
 Supports opaque LSA
    connected
 Number of external LSA 1. Checksum Sum 0x004FF8
    Area BACKBONE(0)
        Number of interfaces in this area is 7
        SPF algorithm last executed 02:52:29.968 ago
        SPF algorithm executed 27 times
        Area ranges are
        Number of LSA 3. Checksum Sum 0x00E8F9
        Flood list length 0
R1 show ip route
R1#sh ip rout
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.15.0.1 to network 0.0.0.0
     172.15.0.0/30 is subnetted, 1 subnets
C       172.15.0.0 is directly connected, FastEthernet0/2/0
     172.17.0.0/24 is subnetted, 1 subnets
C       172.17.0.0 is directly connected, GigabitEthernet0/0.20
     172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C       172.16.0.0/24 is directly connected, GigabitEthernet0/0
C       172.16.1.0/30 is directly connected, GigabitEthernet0/1
     172.19.0.0/24 is subnetted, 1 subnets
C       172.19.0.0 is directly connected, GigabitEthernet0/0.40
     172.18.0.0/24 is subnetted, 1 subnets
C       172.18.0.0 is directly connected, GigabitEthernet0/0.30
     172.20.0.0/24 is subnetted, 1 subnets
C       172.20.0.0 is directly connected, GigabitEthernet0/0.50
O*E2 0.0.0.0/0 [110/1] via 172.15.0.1, 03:08:24, FastEthernet0/2/0
R2 show ip route
R2#sh ip route
Gateway of last resort is not set
michael o'nan
Level 4
Level 4
Since you are using passive-interface default command under router OSPF you will have to configure no passive-interface on each interface where routing adjacencies should form.
So for R2:
router ospf 1
no passive-interface G0/1
R1:
router ospf 1
Try that and see how it works.
michael o'nan
Level 4
Level 4
So for R2:
router ospf 1
R1:
router ospf 1
That did the trick. thanks for the quick response. was driving me crazy. now on to HSRP.
Thanks again
Sudeb Das
We have this issue couple of times. 1 solution for this is to - make the ospf interface point to point with - ip ospf network point-to-point or  ip ospf network broadcast.
Wizard4777
if it's inactive, that means you configured the wrong subnet
