ARP On Cisco Packet Tracer
joaquinjsb
hi im learning to use ARP,  i have a problem with ARP, i have 3 routers and are connected with ARP then, the R1 AND R3 have connection and connection to the R2, but the R2 from the router can access to R1 and R3 but from a device connected to R2, the tracert is lost and can't ping theres a image.
Hi ,
 Share me show ip route from your internet router , i suspect reverse route for 200.88.98.0/x is missing on your internet router ..
Share me show IP route from all 3 routers .
sandy
davrojas
Level 3
Level 3
Hello joaquinjsb,
Which is R1, R2 and R3? Is it:
R2-> Internet and R3-> Orange?
Are you using static routes or a routing protocol?
DAVIDS
