Cisco 7600- RSP reload continuously...
yogesh rajguru
Router with 2 RSP RSP720-3C-GE & Image: c7600rsp72043-advipservicesk9-mz.122-33.SRE2.bin
We are getting the message as
------------------ show version ------------------
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 05-Aug-10 18:59 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE2, RELEASE SOFTWARE (fc1)
Mum-Mha-CR01 uptime is 1 day, 14 hours, 8 minutes
Uptime for this control processor is 14 hours, 49 minutes
System returned to ROM by s/w reset (SP by bus error at PC 0x8359918, address 0x0)
System restarted at 03:07:01 IST Sat Jan 15 2011
System image file is "bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRE2.bin"
Last reload type: Normal Reload
Show log is attached & we are getting %DHCPD-4-DECLINE_CONFLICT: messages contantly.
Was this is reason...
Please help us out for the issue....
7 Replies 7
yogesh rajguru
Again RSP got reload & Got one error message.....
%C7600_PLATFORM-SP-STDBY-3-LOW_BATT: Low Voltage detected for NVRAM Battery
Not able to find about the error message!!!
aljaloudi
Hi Yogesh, please provide us with the following
show context
show stacks
show region
Any recent hardware/software changes?
Thanks for reply!!!!
We have recently upgrade the image from SDR5 to SRE2, thats the only change we have done.
Attaching the Command as requested.
Strange thing is that we got a message saying that %C7600_PLATFORM-SP-STDBY-3-LOW_BATT: Low Voltage detected for NVRAM Battery.
Search a lot for this but couldn't get the confirm reason for it.
If you want exact answer of what it is send a mail to cs-7600@cisco.com
and our HA / OS Infra team will get back with an answer. But what I saw
from internal topic search is that it is a bad HW and a RMA is required.
One of such case is closed with this comment. If you have access to SR
tool look at case no. 612470473
o?caseType=ciscoServiceRequest&method=doQueryByCase&SRNumber=612470473>
Madhu
You must open TAC CASE, also would have consulted TAC before upgrading the IOS.
Could you tell me if you have seen a fib protocol allocation mismatch message during the reloads?
This issue is solved by replacing BOTH batteries, the key word here is BOTH, there are 2 batteries on the sup, one is by the CF and one under the faceplate gasket , left corner. Replacing both with new ones, and reloading the unit, make sure you erase NVRAM and change config-register 0x2102 , reload again and should work. Worked for me.
