AS-Path Access-List Expression
Dipesh Patel
Level 2
Level 2
Dear Experts,
We need to apply As-Path Access-list for allowing any traffic originated from mentioned AS no's (Total 52 no's) and any traffic locally originated.
I have prepared this list :
ip as-path access-list 1 ^$
ip as-path access-list 1 ^64522$
ip as-path access-list 1 ^64523$
ip as-path access-list 1 ^64524$
ip as-path access-list 1 ^64525$
ip as-path access-list 1 ^64526$
ip as-path access-list 1 ^64551$
ip as-path access-list 1 ^64556$
ip as-path access-list 1 ^64557$
ip as-path access-list 1 ^64561$
ip as-path access-list 1 ^64562$
ip as-path access-list 1 ^64563$
ip as-path access-list 1 ^64580$
ip as-path access-list 1 ^64581$
ip as-path access-list 1 ^64582$
ip as-path access-list 1 ^64583$
ip as-path access-list 1 ^64584$
ip as-path access-list 1 ^64585$
ip as-path access-list 1 ^64586$
ip as-path access-list 1 ^64587$
ip as-path access-list 1 ^64588$
ip as-path access-list 1 ^64589$
ip as-path access-list 1 ^64651$
ip as-path access-list 1 ^65429$
ip as-path access-list 1 ^65430$
ip as-path access-list 1 ^65431$
ip as-path access-list 1 ^65432$
ip as-path access-list 1 ^65434$
ip as-path access-list 1 ^65435$
ip as-path access-list 1 ^65436$
ip as-path access-list 1 ^65437$
ip as-path access-list 1 ^65439$
ip as-path access-list 1 ^65462$
ip as-path access-list 1 ^65463$
ip as-path access-list 1 ^65464$
ip as-path access-list 1 ^65465$
ip as-path access-list 1 ^65466$
ip as-path access-list 1 ^65467$
ip as-path access-list 1 ^65468$
ip as-path access-list 1 ^65469$
ip as-path access-list 1 ^65471$
ip as-path access-list 1 ^65518$
ip as-path access-list 1 ^65519$
ip as-path access-list 1 ^65520$
ip as-path access-list 1 ^65521$
ip as-path access-list 1 ^65522$
ip as-path access-list 1 ^65523$
ip as-path access-list 1 ^65524$
ip as-path access-list 1 ^65525$
ip as-path access-list 1 ^65526$
ip as-path access-list 1 ^65527$
ip as-path access-list 1 ^65528$
How can I use in a single line or two line uing AS-Pth Regular Expression?
John Blakley
You could combine these with something like:
ip as-path access-list  1 ^6[4-5][4-6][0-9][0-9]$|^$
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
8 Replies 8
John Blakley
HTH,
John
Here " | " means 6**** or Local Originated ?
Is there any tools like subnet calculator?
Yes, the pipe means OR '|' ^$ (locally originated).
There's not a calculator that I'm aware of, but there are regex testers online that you can use. Here's one that I use:
http://www.regextester.com/
Be sure to select "PREG" before doing your testing. You won't be able to match on the ^$, but you should be able to match on the others by putting the above string in, and then typing individual AS numbers to see if they match. Like I said though, there are plenty of other testers so look around to see which one you like best
HTH,
John
Is it ok if I will use
Sure you can do that too....
HTH,
John
Hi John,
Sorry I missed,
I need to allow advertisement for all network prefixes mention above as well as locally originated network prefixes but need to deny network prefixes originated from below AS no's:
65457
65458
65459
64521
64560
65460
65400
65406
65412
65418
65461
65427
65428
64521
64560
65457
65459
65460
65406
65418
65458
65412
65427
65428
65400
65461
The ealier AS-Path list is matching these  AS no's also.
Pls help.
Also suggest the reff. doc from that I can  have grip on Regular Expression.
IMHO, the easiest way of creating effective  AS-Path lists is following:
1) sort the AS numbers you want to permit.
So your original list sorted looks like:
64522
64523
64524
64525
64526
64551
64556
64557
64561
64562
64563
64580
64581
64582
64583
64584
64585
64586
64587
64588
64589
64651
65429
65430
65431
65432
65434
2) Now you can see what are the digits repeating and you can shrink it a little:
ip as-path access-list 1 permit ^$
ip as-path access-list 1 permit ^6452[2-6]$
ip as-path access-list 1 permit ^64551$
ip as-path access-list 1 permit ^6455[6-7]$
ip as-path access-list 1 permit ^6456[1-3]$
ip as-path access-list 1 permit ^6458[0-9]$
ip as-path access-list 1 permit ^64651$
ip as-path access-list 1 permit ^65429$
ip as-path access-list 1 permit ^6543[0-4]$
I'm afraid this is the shortes AS-Path list covering your request.
3) Generally, you can use a combination of deny and permit entries in your  AS-Path list if necessary.
ip as-path access-list 1 deny ^6455[4-5]$
ip as-path access-list 1 permit ^645[5-6][0-9]$
will permit
^64550$
^64553$
and
^64556$
^64569$
e.g.
HTH,
Milan
Yeah, the original is going to match on anything in the range of 64400 - 65699. As Milan states, since you're going to need to deny prefixes in this range, it may be easier to just create the permits for the ASes that you want to permit and then your as-path access-list would deny anything that isn't permitted in the list explicitly.
HTH,
John
