Problem: MPLS VPN with RIP, OSPF running at CE ends
Roopak Sethi
I am running MPLS VPN with RIP and OSPF at CE ends.
* OSPF  for R3 - R1(ospf process 3) and R4 - R5 (ospf process 4)
* RIP for R4 - R6
I am using two vrfs CA( for R3-R1 and R4-R5) and CB (for R4-R6).
for R1 at R3
ip vrf CA
rd 1:10
route-target export 1:105
route-target export 1:615 // used for R6 to communicate with R1 and R5 for some reasons
route-target import 1:105
route-target import 1:615  // used for R6 to communicate with R1 and R5 for some reasons
for R5 at R4
ip vrf CA
rd 1:50
for R6 at R4
ip vrf CB
rd 1:60
route-target export 1:600
route-target import 1:600
Now  for Communicating R6 with R1 and R5 ( for some reasons)  i am using RT  1:615 both (other wise not needed as previously i was using RT 1:600  only and there was no vrf CB at R3 so to get CA routes into CB i used  1:615 for R6).
My  Problem is :- I am not able to ping R5's loopback ip from R6 as i am  not getting the route for 5.5.5.5 (R5's loopback). But i am able to ping  the serial link ip address of R5.
from R6 to R1 ping is successful
from R1 to R5 ping is successful
from R5 to R1 ping is successful
from R5 to R6 ping is successful
from R6 to R5 ping is unsuccessful ( i am not getting route for R5's loopback). But i am able to ping the serial link ip address of R5.
Kindly help
Topology:-
Configurations:-
R1:-
interface Loopback0
ip address 1.1.1.1 255.0.0.0
ip ospf network point-to-point
interface FastEthernet1/0
duplex half
no keepalive
interface Serial0/0
ip address 10.1.13.1 255.255.255.0
encapsulation ppp
serial restart-delay 0
no dce-terminal-timing-enable
router ospf 1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.1.13.1 0.0.0.0 area 0
network 192.168.1.1 0.0.0.0 area 0
R2:-
mpls label range 200 299
mpls label protocol ldp
interface Loopback0
ip address 2.2.2.2 255.0.0.0
interface FastEthernet0/0
no ip address
duplex half
ip address 10.1.23.2 255.255.255.0
duplex auto
speed auto
mpls ip
ip address 10.1.24.2 255.255.255.0
duplex auto
speed auto
mpls ip
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
network 10.1.23.2 0.0.0.0 area 0
network 10.1.24.2 0.0.0.0 area 0
mpls ldp router-id Loopback0 force
R3:-
ip vrf CA
rd 1:10
mpls label range 300 399
interface Loopback0
ip address 3.3.3.3 255.0.0.0
interface Serial0/0
ip vrf forwarding CA
ip address 10.1.13.3 255.255.255.0
encapsulation ppp
ip address 10.1.23.3 255.255.255.0
duplex auto
speed auto
mpls ip
router ospf 3 vrf CA
redistribute bgp 65001 subnets
network 10.1.13.3 0.0.0.0 area 0
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
network 10.1.23.3 0.0.0.0 area 0
router bgp 65001
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 4.4.4.4 remote-as 65001
neighbor 4.4.4.4 update-source Loopback0
address-family vpnv4
neighbor 4.4.4.4 activate
neighbor 4.4.4.4 send-community both
exit-address-family
address-family ipv4 vrf CA
redistribute ospf 3 vrf CA
no auto-summary
no synchronization
exit-address-family
R4:-
ip vrf CA
rd 1:50
ip vrf CB
rd 1:60
mpls label range 400 499
interface Loopback0
ip address 4.4.4.4 255.0.0.0
interface Serial2/0
ip address 10.1.45.4 255.255.255.0
encapsulation ppp
ip address 10.1.24.4 255.255.255.0
duplex auto
speed auto
mpls ip
ip vrf forwarding CB
ip address 10.1.46.4 255.0.0.0
duplex auto
speed auto
router ospf 4 vrf CA
domain-id 0.0.0.3
network 10.1.45.4 0.0.0.0 area 0
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
network 10.1.24.4 0.0.0.0 area 0
router rip
version 2
address-family ipv4 vrf CB
redistribute bgp 65001 metric 5
network 10.0.0.0
no auto-summary
version 2
exit-address-family
router bgp 65001
neighbor 3.3.3.3 remote-as 65001
neighbor 3.3.3.3 update-source Loopback0
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 send-community both
exit-address-family
redistribute rip
no auto-summary
no synchronization
exit-address-family
redistribute ospf 4 vrf CA
no auto-summary
no synchronization
exit-address-family
R5:-
interface Loopback0
ip address 5.5.5.5 255.0.0.0
ip address 192.168.5.5 255.255.255.0
duplex half
no keepalive
interface Serial0/0
ip address 10.1.45.5 255.255.255.0
encapsulation ppp
router ospf 1
network 5.5.5.5 0.0.0.0 area 0
network 10.1.45.5 0.0.0.0 area 0
network 192.168.5.5 0.0.0.0 area 0
R6:-
interface Loopback0
ip address 6.6.6.6 255.0.0.0
ip address 192.168.6.6 255.255.255.0
duplex half
no keepalive
ip address 10.1.46.6 255.255.255.0
duplex auto
speed auto
router rip
version 2
network 6.0.0.0
network 10.0.0.0
network 192.168.6.0
no auto-summary
Hello Roopak,
Have you tried changing the routers domain ID to the same, I think I read somewhere when mpls is involved with ospf, the process-ID is used with the domain-id, and if the domain-id isn't the same they are consider external to ospf, instead of inter-area type 3.
sh ip bgp vpnv4 vrf CA x.x.x.x | in Domain
res
Paul
Kind Regards
Paul
Hi Paul,
Yes, I tried.. changing domain id on R4 as 0.0.0.3 but it did not helped. Also domain id only ment to convert OE2 routes to O IA. I don't think it can impact because when ospf router are redistributed in BGP then BGP takes OSPF metric as MED and when BGP is redistributed into RIP the same MED value is copied to RIP.
But in my case i was using redistribution metric as 5 so i was seeing every route with metric of 5 in routing table of R6. But route for 5.5.5.5 was not available...
Then, I rebuild the same topology again ( fresh topology) and with same configuration. Now it is working fine.
I think the issue was with GNS.
Thanks for the support.. Paul..
