AS Path access lists
carl_townshend
Hi all
Can anyone tell me how AS path access lists work, if I had the below on my router, what would it do, do they go in sequence etc ?
ip as-path access-list 10 permit _2005_
ip as-path access-list 10 permit _2006_
ip as-path access-list 10 permit _2009
cheers
Carl
Hi Carl,
Like access-list; as-path list also works sequencially.
The sample as-path list is made in conjunction with regex
- This will permit any prefix which will have AS 2005 coming anywhere in between the AS-PATH. However it should not be the first and last AS in the AS-PATH of the prefix.
- Like above explaination, it will allow any prefix which have AS 2006 in between the AS_PATH
- ( if the is no underscrore after 2009, it should generally closed with dollar sign $) will permit any route where AS 2009 is coming anywhere in AS-PATH, but not the first AS.
In case if it is followed by underscore, it can be followed by any other ASes.
If it is ending with $, AS 2009 has to be the last AS in the AS-PATH.
Regard,
Smitesh
I kind of get it
can you please give me another example in your own words, say for 4 routers in 4 different AS paths?
cheers
Carl
to test AS-PATH ACLs you can use either sh ip bgp regexp and the same regular expression you used in your ACL or use sh ip bgp fliter-list 10.I think this is the best way to play with these and understand the regexps in BGP.
Regards.
Alain
