AS path prepend
Roel Reyes
what's the advantage of using this sequence of config? why not simply prepend Upstream2 and dont prepend Upstream1
ip prefix-list Upstream1 description IP Block Incoming Traffic
ip prefix-list Upstream1  seq 20 permit 192.168.0.0/24
ip prefix-list Upstream1  seq 30 permit 192.168.1.0/24
ip prefix-list Upstream1  seq 40 permit 192.168.2.0/24
ip prefix-list Upstream1  seq 50 permit 192.168.3.0/24
ip prefix-list Upstream1 seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Upstream1 -2 description IP Block Incoming Traffic
ip prefix-list Upstream1 -2 seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Upstream1 -3 description IP Block Incoming Traffic
ip prefix-list Upstream1 -3 seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Upstream2 description IP Block Incoming Traffic
ip prefix-list Upstream2 seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Upstream2-2 description IP Block Incoming
ip prefix-list Upstream2-2 seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Upstream2-3 description IP Block Incoming
ip prefix-list Upstream2-3 seq 20 permit 192.168.0.0/24
ip prefix-list Upstream2-3 seq 30 permit 192.168.1.0/24
ip prefix-list Upstream2-3 seq 40 permit 192.168.2.0/24
ip prefix-list Upstream2-3 seq 50 permit 192.168.3.0/24
ip prefix-list Upstream2-3 seq 100 deny 0.0.0.0/0 le 32
route-map Upstream1 permit 10
match ip address prefix-list Upstream1
set as-path prepend 65001
route-map Upstream1 permit 20
match ip address prefix-list Upstream1 -2
set as-path prepend 65001 65001
route-map Upstream1 permit 30
match ip address prefix-list Upstream1 -3
set as-path prepend 65001 65001 65001
route-map Upstream1 permit 40
route-map Upstream2 permit 10
match ip address prefix-list Upstream2
route-map Upstream2 permit 20
match ip address prefix-list Upstream2 -2
route-map Upstream2 permit 30
match ip address prefix-list Upstream2 -3
route-map Upstream2 permit 40
Philip D'Ath
It seems pointless, based on the information, to path-prepend both.
Roel Reyes
Anymore inputs? this is currently an ISP config
Julio E. Moisa
It does not make sense, the sequence 20 and 30 are not being used. it could be a misconfiguration.
Also this line could be removed
ip prefix-list Upstream1 seq 100 deny 0.0.0.0/0 le 32  as my understanding you are just matching some prefixes to assign the attribute.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
