AS5300 - - - IOS - - - Corrupted
afzaalqadir
I have IOS upgradation problem as i alredy discuued the problemm with you.
My AS5300 rommon and after changing the config register value ti its orignal 0X2102 and after the reset the out put comes with different Errors.
plz chk the output and suggest the possible solution,
System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
AS5300 platform with 131072 Kbytes of main memory
rommon 1 > ?
alias set and display aliases command
boot boot up an external process
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
xmodem x/y modem download
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 3 > reset
loadprog: error - trouble reading file magic number
open: failed to find and/or load the bootloader: "bootflash:c5300-js-mz.123-15.bin"
loadprog: error - on file open
boot: cannot load "cisco2-AS5300"
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
boot: cannot load "bootflash:"
rommon 1 >
Waiting for your replay
Thanks and regards.
7 Replies 7
ankurbhasin
Level 9
Level 9
Hi Friend,
"BAD magic number" which gives me a meaning that you have a corrupt image on your bootflash.
WHY don't you format the flash and xmodem the image again and I hope that should take care of the issue.
HTH, if yes please rate the post.
Ankur
Now i have only way to formate or erase boot flash through Xmodem
but it did not work . plz tell me the method for formate the boot flash:
thanks
Hi Friend,
I know there is no format command available and neither I have done it on access servers.
Can you try xmodem without format and see if it prompts for overwritting the current image or something like that.
Ankur
You can also tftp to the AS5300 the commands are exactly the same as on a 2600. Just make sure everything is exactly as it is below. rommon is very picky about it being case sensitive. Just substitute your variables and you should be good to go.
rommon 15 > tftpdnld
rommon 16 > IP_ADDRESS=171.68.171.0
rommon 17 > IP_SUBNET_MASK=255.255.254.0
rommon 18 > DEFAULT_GATEWAY=171.68.170.3
rommon 19 > TFTP_SERVER=171.69.1.129
rommon 20 > TFTP_FILE=c2600-is-mz.113-2.0.3.Q
rommon 21 > tftpdnld
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Patrick
Please rate any posts that are helpful.
csco10837896
check with the following
Router boots in boot mode, with the following messages on the console:
magic number
device "flash:"
ans:
The Flash is empty or the filesystem is corrupted. Copy a valid image on the Flash, and while copying, you will be prompted to erase the old Flash (if one exists). Then reload the router.
Try with this link
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
Pls Rate this post
Yogesh
i have tried the procedure from the link you sent me.
i have problem that when i copy new image throuh Xmodem it copied in the boot flash not in the flash plz chk the output of commands
rommon 1 > dev
Devices in device table:
id name
flash:1: flash partion 1 has no valid image
bootflash: boot flash
rommon 3 > dir flash:1
dir: cannot open device "flash:1"
rommon 4 >
rommon 4 > dir bootflash:
File size Checksum File name
0 bytes (0x0) 0xffff c5300-js-mz.123-15.bin
rommon 6 >boot bootflash: c5300-js-mz.123-15.bin
monitor: command "Cboot" not found
I have told you that image is coping in boot flash not in the flash and comes of no space with me when i copy the image.
thanks and waiting for ur response.
plz check the output i have sent you in the privous mail.
and suugest !!!!!
Thanks waiting for your response..
