ASA 5505 Access Internet from VLAN
stephilewis
stephilewis wrote:
No I cannot access http, when i create a route "route BeneNetwork 10.10.220.0 255.255.255.0 172.16.20.100" i get connected route exist.
the default route on my client is 10.10.220.100 which is the ip for the vlan benenetwork.
Ahh, i thought you were connecting from the inside interface but it looks like you are coming from the BeneNetwork. Add this to your config -
nat (BeneNetwork) 1 0.0.0.0 0.0.0.0
Jon
6 Replies 6
Jon Marshall
stephilewis wrote:
I configured our ASA 5505 with two VLAN's one is for our wireless network and one is for our internal network.  This issue I am having is I cannot access the internet from our internal network.  I can ping from the ASA to the internet and to the internal network but not the other way around.  Do I need to setup an access list for this?
Stephen
When you say you can't access the internet is that with ping ? If so ping is slightly different than for example accessing a web site. Have you tried accessing a web site from an inside client.
If you do want to test ping then there are a couple of things you can do but you do need to modify your config -
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
Jon
neither, I can ping the internal network vlan address, but not the inside address or any address after this up to and including the outside interface.  I can ping anywhere from the console.
Sorry Stephen, could you clarify. You have or haven't tried to use http ?
You can ping the internal vlan address but not the inside address. Does this mean your default-gateway on the client is not the ASA ? If it isn't then you need to -
1) add a route, probably a default-route on this device pointing to the ASA inside IP
2) add a route on the ASA for the subnet your client is on so the ASA knows how to route back to your client
Jon
Jon
Excellent this worked for http, the next step will be for me to allow access from WLAN to BeneNetwork.  I will try to figure this out, but may be back to search out a way.
Thanks Jon!!!!
