Tom Hoffman wrote:
Just acquired a 5505. Before I rip out what little hair remains on my head - thought I'd ask if this is even possible.
Goal:
Site-to-Site VPN with our local office to Main Office (both on different static IPs - only our side uses the 5505)
[Main Office ] <<< >>> {cloud} <<<>>> [ADSL Model] <<< >>> [Cisco 5505} <<< >>> [local office private subnet]
AND - Use Easy VPN to remote into the 5505 when we are out of the local office and possibly gain access back to Main office.
So - is this doable?
Provided your "outside" static IP's are internet-accessable (I.E. not on a private MPLS cloud or something similar) then yes, it should be.
The exact methods of your Anyconnect/Site to site VPN's will depend on your licensing levels - you need to license AnyConnect (easyVPN) based on the number of users, and you may also need to license encryption beyond single DES (56 bit).
This file
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
gives basic product information regarding the capabilities.
This link
http://www.cisco.com/en/US/products/ps6120/products_data_sheets_list.html
gives more detailed data sheets.
Cheers.
