ASA 5505: No internet with a static IP
EjlskovCisco
I've having a problem with our company ASA5505 router.
We recently moved to a new adress, so everything had to be set up again. I have a static IP, submask and gateway from our new ISP. The router have been factory reset before moving. We have betweeen 10-20 employees on our LAN in the office. In an attempt to make things easier I have changed the internal IP (and IP range) to 10.0.200.1 with a range from 10.0.200.5 - 10.0.200.100 as our NAS/printer/plotter have IPs within this range.
I can ping machines on the internal IPs and in ASDM the Outside interface is show as "up" with a green arrow. But there still isn't any internet connection. The only thing I haven't tried (because people need the current network to be online) is changing
"route inside 0.0.0.0 0.0.0.0 62.242.X.X 1" to "route outside 0.0.0.0 0.0.0.0 62.242.X.X 1"
Can you guys see if anything else should be changed for this to work? I have recieved a primary and secondary DNS adress as well, but I'm in doubt as to were I'm supposed to enter these (Using ASDM Version 6.3). I would like everything "Behind" the router to be run by DHCP.
Here is the running config:
ASA Version 8.2(2)
hostname ciscoasa
enable password X
passwd X
names
interface Vlan1
nameif inside
security-level 100
ip address 10.0.200.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 62.242.X.X 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns domain-lookup inside
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.0.200.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 194.239.X.X 193.162.X.X
dhcpd auto_config outside
dhcpd address 10.0.200.5-10.0.200.100 inside
dhcpd dns 194.239.X.X 193.162.X.X interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:28ad57e19743b0f3ca5b728c6ac89c23
: end
John Blakley
Dennis,
Try to ping the gateway from the ASA. If that's successful, try to ping 4.2.2.1 from a workstation. If that works, then it's a dns issue somewhere. If it does not work, it's a nat issue. If you can't ping it from the ASA, make sure that the new ISP has bridged the modem/router that they provide. I'm assuming this is a cable/dsl connection, and if that's the case I'm leaning toward the modem/router not being bridged.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John.
Thank you for that checklist! I will have to wait untill after hours to test it though. The connection is actual a fiber. It's a dualfiber cable being converted by a Raycore box with only a RJ45 output named "LAN". I assume, maybe incorrectly, that this box only converts the signal. This would make the 5505 the only router connected. Image attached below.
Thank you,
Dennis
EjlskovCisco
Ok, so now I tried setting up an outside route with the provided gateway adress. I still can't ping outside from my machine, that is, untill I change the DNS on my own machine. Suddenly I got internet along with NAS/printer and so on.
So my problem is getting the 5505 to supply my machines a DNS adress automaticly. Any tips as to where the correct place for the DNS adress is?
Dennis
EjlskovCisco
Ok, got everything working now.
Under Configuration -> Device management -> DNS - > DNS Client. Here I configured the DNS setup as one group and under DNS lookup I enabled DNS for the inside interface and added the primary and secondary DNS fra my ISP. Voilá, internet and network funktioning.
Thought I would add the solution for anyone stumbeling over this post later on. Now I just need to setup VPN for the first time ever :S
Dennis
