ASA 5506x error message: 528FAIL re_compile not all rules are compiled
Phoneguy-Mike
We are having an issue with our ASA 5506x router. Recently the router would stop responding to client VPN requests and when trying to access the unit with ASDM it would just hang. Power cycling the unit would return normal function for a few days but then exhibit the same behavior.
Connecting to the unit using a console cable does work. When connected the console repeatedly shows the following message, which I have searched for but get no results.
% Failed to allocate regular expression state table: 528FAIL re_compile, not all rules are compiled
Based on the wording I would guess it has something to do with the firewall rules but I can't find any information on this message.
Any insight you can offer would be greatly appreciated. Thank you
P.S. I wasn't sure where I should put this post, hopefully this is the right place.
Mark Elsen
          - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtd34212
   Reboot the ASA , afterwards look at the current software version and check if more recent (advisory) release(s) are
   available , if so upgrade ,
M.
Mark Elsen
M.
Thank you for the reply. The link was very helpful.
We did identify memory exhaustion as a possible cause and this helps confirm that. Unfortunately, management let our support contract expire so we do not have access to firmware updates. However, this device is EOL anyway so this is a good excuse to replace it.
Thank you again.
Link info repeated for webrot purposes:
Unexpected ACL recompile failure messages
BugID: CSCtd34212
Description
Symptom: Due to memory exhaustion issues ACLs were not properly compiled and traffic was failing.
Conditions: While working on a 5520 in the solution test set up and trying to run a mix of HTTP, SMTP, DNS, SIP traffic it was observed from the Agilent test tool that the SMTP traffic was not passing. Upon further review the following messages were seen on the console: % Failed to allocate regular expression state table: 520FAIL re_compile, not all rules are compiled
This appears to be a memory exhaustion issue.
Workaround: None
