ospf nssa
bluesea2010
Level 5
Level 5
I'm considering implementing the following campus network topology: SW1 and SW2 will be configured as stacked access switches, with up to four switches allowed per stack. Each stack will run Layer 3 OSPF and can advertise up to 10 networks. At Site 1, there will be 30 stack switches, and at Site 2, there will be 10 stack switches. I am exploring the possibility of implementing an NSSA in each stack. What would be the advantages and disadvantages of this approach?ospf.jpg
Hello
Are you expecting to redistribute external routes from either non BB area (10-20) if not then you not need NSSA, just totally sub areas would be as good. in either case the effects would be to drastically cut down the topologys database sizes to both of those areas
Kind Regards
Paul
bluesea2010
Level 5
Level 5
Currently its  all areas are normal , I want to move slowly to nssa or totally stub
what is the good practice for this , it wont be possible  all at once
Joseph W. Doherty
"What would be the advantages and disadvantages of this approach?"
Advantages (for this sized topology), little.
Disadvantages, amount of work to convert and additional complexity.
Other than you could do this, why do you believe it should be done?
I ask, because from the kind and size of the topology, seems unnecessary.
The critical "weakness" of OSPF, is running Dijkstra's algorithm, per area.  What you describe, is up to 32 nodes, 30 with just a link to each core.  Pretty trivial.
You also might be concerned by number of routes, like 300 plus in site 1, or about 400 plus, globally.  Also that's pretty trivial.
However, an an alternative to using any kind of stub area, you can summarize an area's routes being advertised to area zero. (Of course for that to work well, area addresses need to be in nice summarizable address blocks.)
BTW, I've very large OSPF network experience, much, much (much) larger than you describe, and we didn't use stubs.  Heck, I had one building using Catalyst 6513s with eleven 96 port line cards hosting VoIP phones and PCs.  That one, port wise, equivalent to five and a half of your stacks, assuming stack members are 48 port.  Such an OSPF node, was part of an area that encompassed other sites across multiple states, where sites might have multiple buildings and/or buildings of multiple floors and/or multiple L3 nodes per floor.  Oh, and L3 OSPF platforms ranged from 800 series ISRs, switch stacks, to 6500s.
So from direct experience, again, why do you believe your network, as described, "needs" stubs?
