ASA 5508-x step by step GUI configuration guide
dipakcisco
Hi All,
I have bought ASA 5508-X for my office new network setup.
we are planning to have 3 different servers on 3 different public IP's and 3 different local IP networks.
we have 5 public IP pool from our ISP.
90.x.x.x ----> 172.16.10.x   for web server
90.x.x.x ----> 172.16.20.x for mail server
90.x.x.x ----> 172.16.1.x for local network
I would like to configure secure network with the services enabled VPN, VLAN, security protocols, and so on.
is there any of you can able to provide me step-by-step configuration guide for this kind of network setup.
Also any of you have any suggestion for better network setup, please advise.
DP
chrisgray1
Hi there,
step by step configuration guide is a bit tricky but what you essentially want is NAT for the web and mail server so they can reach the internet.
NAT for the public facing.
90.x.x.1 > web server
90.x.x2 > mail server
external interface = VPN
Your 3 networks would be separated by vlans on the 5508 with security levels for each one. So that the internal network can access the other networks but they cannot by default reach it.
the outside interface has an ACL which restricts any inbound traffic other than to the web server, mail server, VPN.
The VPN part you can use the wizard in the ASA ASDM .
There are the basic setup guides for the ASA and honestly for quick start youtube will help you to configure these basics,
Hi Chris,
Thanks for your suggestions, I will try to follow it.
if you have any other suggestions / advise please update it .
