ASA 5510 not pinging out backup interface (trying to setup failover through SLA)
bhirschtick
I am trying to setup failover via SLA monitoring and I am having an issue with the backup interface.  I have a Cisco ASA 5510 that has 2 ISPs on an outside interface and a backup interface.  The outside interface can ping successfully to a public IP (8.8.8.8) however the backup interface cannot ping to any public IP however it can ping to the gateway.  I have plugged in my laptop directly to the gateway and supplied it with the same IP address as the ASA backup interface, this was able to ping to public IPs.
I have tried the following configurations to troubleshoot the issue:
-ICMP permit any backup echo
-ICMP permit any backup echo-reply
-access-list 101 extended permit icmp any any echo
-access-list 101 extended permit icmp any any echo-reply
-I have also removed any ACL from the interface
-I created a new ACL with permits everything
NONE of these worked.
Below is the ASA 5510 firewall configuration:
ASA Version 8.2(5)
interface Ethernet0/0
 nameif inside
 security-level 100
 ip address ZZ.ZZZ.ZZ.ZZZ 255.255.255.0
interface Ethernet0/1
 nameif outside
 security-level 0
 ip address XX.XXX.XX.XX 255.0.0.0
interface Ethernet0/2
 nameif backup
 security-level 0
 ip address YY.YY.YYY.YYY 255.255.255.248
interface Ethernet0/3
 nameif Voice
 security-level 100
 ip address 10.1.10.1 255.255.255.0
boot system disk0:/asa825-k8.bin
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list 101 extended permit tcp 64.18.0.0 255.255.240.0 interface backup eq smtp
access-list 101 extended permit ip 38.98.142.0 255.255.255.192 any
access-list 101 extended permit tcp any interface backup eq 3389
access-list 101 extended permit tcp any interface backup eq www
access-list 101 extended permit tcp any interface backup eq pop3
access-list 101 extended permit ip 10.1.10.0 255.255.255.0 10.2.10.0 255.255.255.0
access-list 101 extended permit tcp 74.217.1.192 255.255.255.192 any eq 3389
access-list 101 extended permit ip interface backup host 8.8.8.8
access-list 102 extended permit ip any any
access-list outside_cryptomap_20 extended permit ip 192.168.24.0 255.255.255.0 192.168.25.0 255.255.255.0
access-list outside_cryptomap_20 extended permit ip 10.1.10.0 255.255.255.0 10.2.10.0 255.255.255.0
access-list to-voice extended permit ip any any
access-list 105 extended permit ip 10.2.10.0 255.255.255.0 10.1.10.0 255.255.255.0
access-list DC extended permit ip 192.168.24.0 255.255.255.0 10.168.24.0 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 60
global (inside) 1 interface
global (outside) 1 interface
global (backup) 1 interface
static (inside,backup) tcp interface www 192.168.24.4 www netmask 255.255.255.255
static (inside,backup) tcp interface pop3 192.168.24.4 pop3 netmask 255.255.255.255
static (inside,outside) tcp interface pop3 192.168.24.5 pop3 netmask 255.255.255.255
static (inside,outside) tcp interface www 192.168.24.230 www netmask 255.255.255.255
static (inside,outside) tcp interface smtp 192.168.24.230 smtp netmask 255.255.255.255
static (inside,backup) tcp interface smtp 192.168.24.230 smtp netmask 255.255.255.255
static (inside,backup) tcp interface 3389 192.168.24.4 3389 netmask 255.255.255.255
static (inside,outside) tcp interface 3389 192.168.24.5 3389 netmask 255.255.255.255
static (inside,outside) 216.90.254.3 192.168.24.70 netmask 255.255.255.255
static (inside,Voice) 192.168.24.0 192.168.24.0 netmask 255.255.255.0
static (inside,outside) 38.102.48.165 192.168.24.215 netmask 255.255.255.255
static (inside,outside) 38.102.48.166 192.168.24.212 netmask 255.255.255.255
static (inside,backup) 12.23.172.235 192.168.24.70 netmask 255.255.255.255
access-group 100 in interface outside
access-group 101 in interface backup
route outside 0.0.0.0 0.0.0.0 XX.XXX.XX.XX 1 track 1
route backup 0.0.0.0 0.0.0.0 YY.YY.YYY.YYY 254
sla monitor 123
 type echo protocol ipIcmpEcho 8.8.8.8 interface outside
 num-packets 6
 frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
class-map inspection_default
 match default-inspection-traffic
class-map Voice-OUT
 match access-list 105
class-map Voice-IN
 match access-list 100
policy-map type inspect dns migrated_dns_map_1
 parameters
  message-length maximum 1024
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
policy-map Voicepolicy
 class Voice-IN
 class Voice-OUT
  priority
service-policy global_policy global
service-policy Voicepolicy interface outside
service-policy Voicepolicy interface backup
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:2cafbdd9066cce7e9ed72359c55de19c
: end
HERE IS THE GATEWAY CONFIG:
!This configuration has had sensitive information
! scrubbed out.  Please report any flaws to:
!        dl-att-action@ems.att.com
! Copyright © 2014 AT&T.  All rights reserved.
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime
service password-encryption
hostname USMELTSCHIL02R
boot-start-marker
boot system SCRUBBED
boot-end-marker
card type t1 1 1
logging buffered 32000
no logging console
enable secret 5 SCRUBBED
aaa new-model
aaa group server radius h323
 server SCRUBBED auth-port 1812 acct-port 1813
 server SCRUBBED auth-port 1826 acct-port 1827
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting connection h323 stop-only group radius group h323
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone GMT 0 0
network-clock-participate slot 1
no ipv6 cef
no ip source-route
no ip mfib
no ip domain lookup
ip cef
isdn switch-type primary-ni
key SCRUBBED
 key SCRUBBED
  key-string SCRUBBED
voice-card 0
 dspfarm
 dsp services dspfarm
voice-card 1
 dspfarm
voice service voip
 fax protocol t38 version 0 ls-redundancy 1 hs-redundancy 0 fallback pass-through g711ulaw
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  min-se 900 session-expires 900
  asserted-id pai
  privacy pstn
voice class codec 1
 codec preference 1 g729br8
 codec preference 2 g729r8
 codec preference 3 g711ulaw
voice vad-time 65536
license udi pid C3900-SPE250/K9 sn  SCRUBBED
hw-module pvdm 0/0
hw-module pvdm 0/1
dial-control-mib retain-timer 10080
redundancy
controller T1 1/0
 clock source internal
 pri-group timeslots 1-24
 description att-unman
controller T1 1/1
 shutdown
ip telnet source-interface Loopback0
ip tftp source-interface Loopback0
ip ssh version 2
class-map match-any NMC_RP
 description Traffic due to dynamic routing (BGP)
 match access-group 178
class-map match-any NMC_SNMP
 description Network Management traffic
 match access-group 180
 description BGP + SNMP traffic
class-map match-all COS3_SAA
 description COS1 SAA traffic
 match ip dscp af21
 match access-group 179
class-map match-all COS2_SAA
 match ip dscp af31
class-map match-all COS1_SAA
 match ip dscp ef
class-map match-all COS4_SAA
 match ip dscp default
class-map match-any COS4_TRAFFIC
 description Best Effort traffic
 match access-group 184
 match class-map COS4_SAA
 match class-map COS4_TRAFFIC
class-map match-any COS3_TRAFFIC
 match access-group 183
 match class-map COS3_SAA
 match class-map COS3_TRAFFIC
class-map match-any COS2_TRAFFIC
 description COS2 traffic
 match access-group 182
 match class-map COS2_SAA
 match class-map COS2_TRAFFIC
class-map match-any COS1_TRAFFIC
 description Real-Time traffic
 match access-group 181
 match access-group 185
 match ip dscp ef
 match class-map COS1_SAA
 match class-map COS1_TRAFFIC
class-map match-any COS3_NONCONF
 match ip dscp af22
class-map match-any COS2_NONCONF
 match ip dscp af32
policy-map NMC_CLASSIFICATION
 class NMC_RP
  police cir 16000 bc 8000 be 8000
   conform-action set-dscp-transmit cs6
   exceed-action set-dscp-transmit cs6
 class NMC_SNMP
   conform-action set-dscp-transmit af21
   exceed-action set-dscp-transmit af21
policy-map COS4_CLASSIFICATION
 class COS4_TRAFFIC
  police cir 1979500 bc 247450 be 247450
   conform-action set-dscp-transmit default
   exceed-action set-dscp-transmit default
policy-map COS1_CLASSIFICATION
 class COS1_TRAFFIC
  police cir 17816000 bc 2227050 be 2227050
   conform-action set-dscp-transmit ef
   exceed-action drop
policy-map CE_EGRESS_QUEUING
 class NMC
  bandwidth remaining percent 10
  random-detect dscp-based
  random-detect dscp 18 200 300 10
  random-detect dscp 48 200 300 10
  service-policy NMC_CLASSIFICATION
 class COS1
  priority
  queue-limit 4096 packets
  service-policy COS1_CLASSIFICATION
 class COS4
  bandwidth remaining percent 89
  random-detect exponential-weighting-constant 1
  random-detect dscp 0 100 200 10
  service-policy COS4_CLASSIFICATION
policy-map EA_EGRESS_QUEUING
 class class-default
  shape average 19796000
  service-policy CE_EGRESS_QUEUING
interface Loopback0
 ip address 12.67.31.44 255.255.255.255
interface GigabitEthernet0/0
 description connection to customer LAN
 ip address 12.23.172.233 255.255.255.248
 no ip redirects
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/1
 description connection to CBB DHEC.111111
 ip address 12.251.126.206 255.255.255.252
 ip access-group inb-serial in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex full
 speed 100
 no cdp enable
 service-policy output EA_EGRESS_QUEUING
ip route 0.0.0.0 0.0.0.0 12.251.126.205
ip tacacs source-interface Loopback0
ip access-list extended inb-serial
 permit icmp any 12.23.172.232 0.0.0.7
 deny   ip 127.0.0.0 0.255.255.255 any
 permit udp any host 12.67.31.44 range 16384 32768
 permit udp 12.194.0.0 0.0.255.255 host 12.67.31.44 gt 1023
 permit tcp 12.194.0.0 0.0.255.255 host 12.67.31.44 gt 1023
 permit udp any eq domain host 12.67.31.44 gt 1023
 deny   udp any any eq 5060
 deny   tcp any any eq 5060
 permit ip SCRUBBED 0.0.0.7 any
 permit ip SCRUBBED 0.0.0.15 any
 permit ip SCRUBBED 0.0.0.127 any
 permit ip 12.38.8.128 0.0.0.127 any
 deny   udp any any eq snmp
 deny   udp any any eq snmptrap
 permit ip SCRUBBED 0.0.0.255 any
 permit ip SCRUBBED 0.0.0.252 any
 permit icmp any host 12.67.31.44
 permit icmp any host 12.23.172.233
 permit ip 135.45.105.0 0.0.0.255 any
 deny   ip any host 12.23.172.233
 deny   ip 12.23.172.232 0.0.0.7 any
 deny   ip 10.0.0.0 0.255.255.255 any
 deny   ip 172.16.0.0 0.15.255.255 any
 deny   ip 192.168.0.0 0.0.255.255 any
 permit ip any 12.23.172.232 0.0.0.7
 permit tcp any any eq bgp
ip radius source-interface Loopback0
ip sla key-chain probe-key
logging source-interface Loopback0
logging SCRUBBED
logging SCRUBBED
access-list 5 permit 12.38.8.226
access-list 7 deny   any
access-list 84 deny   any
access-list 178 remark BGP Traffic (NMC_RP)
access-list 178 permit tcp any eq bgp any
access-list 178 permit tcp any any eq bgp
access-list 179 remark SAA Traffic (Delay & Jitter)
access-list 179 permit icmp host YY.YY.YYY.YY any echo
access-list 179 permit udp host YY.YY.YYY.YY any eq 1967
access-list 179 permit udp host YY.YY.YYY.YY any eq 16181
access-list 179 permit udp host YY.YY.YYY.YY eq 16181 any
access-list 181 remark COS1 Traffic (Real-Time)
access-list 181 permit udp host 12.67.31.44 any range 16384 32767
no cdp run
nls resp-timeout 1
cpd cr-id 1
cadet alain
This is normal behavior as the second static route( the floating one pointing out backup) is not installed as long as first one is in the routing table.So it shouldn't appear in sh route output but as soon as outside interface goes down then backup default route will get installed and you'll be able to ping 8.8.8.8 from it.
Alain
I have used the commande "ping backup 8.8.8.8"  which to my knowledge initiates the ping from the backup interface.  Would this still work regardless of the active route?
No, the ASA needs a route for the destination and the only route in the routing table  that matches 8.8.8.8 is the default route on the outside interface.
Alain
I was just checking, but even when we had it as the primary route, it still would not ping.
