ASA 5515: How to nat service group objects
Sina Owolabi
I have a load balancer I am trying to nat multiple ports to (at this time, http and https) behind an ASA 5515.
I have created a service group for the nat ports:
object-group service webServices
  service-object tcp destination eq www
  service-object tcp destination eq https
I created an object for the host:
object network lb01
 host 192.168.72.13
and an access-list rule:
access-list outside_in extended permit object-group webServices any object nglb01
But when I try to add a nat rule for the network object like this:
nat (dmz,outside) static interface service tcp webServices webServices
It returns errors.
Please what is the correct way to do this? I want to be able to NAT ports 80, and 443 to the load balancer.
Sina Owolabi
This is what I ended up doing, which works, despite complaints of something overlapping from the ASA. It doesn't conflict with anything else.
I am worried if later rules might make trouble if they are similar. Any advice?
My config:
object network lb01
host 192.168.72.13
object network lb01
nat (dmz,outside) static outside.27  ** source of ASA overlap complaints
object network outside.27
host 154.X.X.27
access-list outside_in extended permit object-group webServices any object lb01
