ASA 5516-X - Routing Inside to another Interface
mfdarvesh
Network diagram is above, Firewall is configured to give internet access to few clients and site to site VPN to few outside entities. My organization recently acquired a web application and they give IP: 192.168.200.98 and Gateway: 192.168.200.97 and web url 10.10.10.25. Now I configured these IPs on laptop and application is working in Google Chrome. I want that Inside network client e.g. 192.168.25.x should be able to access this AQ Network. Assigned these IPs to a Firewall Port, what configuration is required to route traffic 10.10.10.25 to 192.168.100.97 ??
first i cannot see 10.10.10.25 ip range in your diagram.
normally firewall will do routing for directly connected networks if you have added relevant firewall policies. if network not directly connected , you can add static/dynamic routing to get network visibility to firewall.
Good luck
KB
johnlloyd_13
Level 9
Level 9
hi,
configure AQ nameif with the same security level with inside (usually it's 100).
then configure same-security-traffic permit inter-interface.
follow
Hello
As long as the interfaces are of the same security level then as stated - same-security-traffic permit inter-interface  should be applicable to allow communication
Kind Regards
Paul
