ASA 5516-X
Senbonzakura
Good morning everyone, I need some personal thoughts.
Currently, I have a setup I've been working on. I had to redesign my network, after getting a new firewall this is how it goes. My modem, connects to my firewall which is configured to do the routing. One port feeds my switches for the internal network, out of another port of the firewall we have our WiFi then out of another port we have the guest WiFi. The security level for the inside network with switches is set to 100.
For the Guest network and Home WiFi network that are coming from different ports on the firewall, for it being considered "inside" the network what do you think would be considered a good security level for the two segments?
Cristian Matei
   Assuming your outside has a security-level of 0 and your inside a security level of 100, you have two options:
         - use the same security level value for both WiFi networks (this way they can't communicate in between by default) and give it a security-level of whatever you want , between 1 and 99, like birth being 60 for example. With these security levels, your WiFi users will be allowed to go out on the Internet only by default, for other access configure an ingress ACL or global ACL.
       - use different security levels for your two WiFi zones, like 60 and 70 for example, and put the Guest to 60; with this, Guest will be allowed out on the internet only, while the other wifi network will be allowed to a access the Internet and the guest wifi network; likewise these default permissions based on security levels can be overridden by ACL's.
Cristian Matei.
7 Replies 7
Cristian Matei
Cristian Matei.
Thanks for that, it makes sense. I'm going to pick your brain a little bit more, I'm trying to do something a little bit different. I'll lay it out for you because I want to try and make something else work.
So the modem - > Firewall then the firewall connects to two different ISRs, the reason why two is because I'm running HSRP on them and the second ISR is for redundancy only which are both hooked up into a switch. Right now, I'm only trying to ping the main ISR and I can ping the gateway but when I try to ping the exit port I don't get anything back.
Experimental setup here.
On switch:
Interfance G1/0/35
Switchport mode trunk
VLAN 250
192.168.0.2 255.255.255.0
On Router: (HSRP isn't setup yet but will be)
Interface G0/0.1
Encapsulation DOTQ1 VLAN 250
192.168.0.1 255.255.255.0
Interface G0/1
208.165.100.2 255.255.255.252
IP Route 0.0.0.0 0.0.0.0 208.165.100.1
IP Route 192.168.0.0 208.165.100.1
On Firewall:
Interface E0/3
208.165.100.1 255.255.255.252
Route Inside 0.0.0.0 0.0.0.0 208.165.100.2
then after it goes through the firewall I want it to go to the modem which is bridged. Lets say E0/1 interface is 68.36.235.5 255.255.252.0
Network: 68.36.232.0
Gateway: 68.36.232.1
Should I configure the Firewall to hand out DHCP or the ISR, which would be recommended?
Now i'm still trying to learn how to configure the firewall properly but I cannot ping the routers exit interface and the firewalls interface from the VLAN 250 within the switch. What am I doing wrong or missing?
   Are you trying to ping from the switch which is in front of the firewall, across the firewall to the ISR's behind the firewall? You need to allow that traffic through the ASA, but i would not open this "hole" in the firewall, if the design is as i described.
   For which users do you want to use DHCP? For the users attached to the ASA (WiFi) or for internal users (behind ISR's i believe)?
Cristian Matei.
I'm trying to ping from the switch to the Firewalls Interface that's connected to the ISR and afterwards I'd like to be able to ping past the firewall but I'm not sure if I have the routing correct and how to allow traffic.
I was thinking of creating multiple DHCP pools, one for the Guest WiFi, one for the Main WiFi then another for our main ethernet network. Should I have the Router hand out DHCP which is after the firewall or should I just have the Firewall do it? Everything device before the DHCP will just be statically configured like the interfaces between the firewall and the modem.
   1. As said, i would not allow that traffic through; but if you want to do it (if it's ASA firewall, you can only ping the interface closest to you from touting perspective, your ICMP packets cannot cross the ASA and land on it):
           access-list OUTSIDE_IN extended permit icmp host switch host ISR"
           access-group OUTSIDE_IN in interface outside
   2. I would go simple, as the ASA DHCP Relay functionality has some restrictions; i would leave the ASA run as DHCP server for your WiFi users for which it will also be default gateway, and have the ISR routers run as DHCP server for your internal users.
Cristian Matei.
That actually does make a lot of sense and is a lot more simple, thank you for clearing that up.
As far as things with the routing table, do I have that correct so far? Or does it need something additional?
    Post a diagram with the devices, how are they connected, which IP subnets are where, where is the ISP, what is the ISP interconnect?
Cristian Matei.
