ASA 5520 EIGRP Route Filtering
Darren Roback
Level 5
Level 5
I have an ASA 5520 connected to a Cisco 6509E, and we're turning up EIGRP between the two. The problem that I'm running into is that there a few static routes (including a 0.0.0.0) on the core that's being redistributed into the EIGRP AS, and I need to block this from being propagated to the ASA. The ASA only has the capability to use an ACL in conjunction with a distribute-list, and I can't find a way to filter the default route (0.0.0.0 /0), while allowing everything else.
Any suggestions?
Thanks!
Darren
John Blakley
I don't have an ASA that I can test, but you can try this:
access-list DenyDefault deny ip 0.0.0.0 0.0.0.0 (being an ASA, you may have to change this to 0.0.0.0 255.255.255.255)
access-list DenyDefault permit ip any any
router eigrp 100
distribute-list DenyDefault in
I would definitely make this change after hours since I'm not sure how this will affect it. The ACL syntax probably isn't right, but I don't have an ASA running eigrp.
HTH, John *** Please rate all useful posts ***
Thanks for the reply j.blakley. I ended up denying the 0.0.0.0 host, and took it a step further with some RRI. Here's part of my codebase:
ASA5520STL01# sh run access-list
access-list Redistribute_Connected_Tunnels standard permit 192.168.12.48 255.255.255.240
access-list Redistribute_Connected_Tunnels standard permit 192.168.12.32 255.255.255.240
access-list Redistribute_Connected_Tunnels standard permit 192.168.3.80 255.255.255.240
access-list Redistribute_Connected_Tunnels standard permit 192.168.3.144 255.255.255.240
access-list Redistribute_Connected_Tunnels standard permit 192.168.12.64 255.255.255.240
access-list EIGRP_In_From_Core standard deny 192.168.3.80 255.255.255.240
access-list EIGRP_In_From_Core standard deny 192.168.3.144 255.255.255.240
access-list EIGRP_In_From_Core standard deny 192.168.12.0 255.255.255.0
access-list EIGRP_In_From_Core standard deny 192.168.3.0 255.255.255.0
access-list EIGRP_In_From_Core standard deny 192.168.0.0 255.255.0.0
access-list EIGRP_In_From_Core standard deny host 0.0.0.0
access-list EIGRP_In_From_Core standard permit any
ASA5520STL01# sh run crypto map
crypto map Outside_map 2 match address Outside_2_cryptomap
crypto map Outside_map 2 set peer X.X.X.X
crypto map Outside_map 2 set transform-set ESP-AES-128-MD5
crypto map Outside_map 2 set reverse-route
crypto map Outside_map 3 match address Outside_cryptomap
crypto map Outside_map 3 set peer X.X.X.X
crypto map Outside_map 3 set transform-set ESP-AES-128-MD5
crypto map Outside_map 3 set reverse-route
crypto map Outside_map 4 match address Outside_4_cryptomap
crypto map Outside_map 4 set peer X.X.X.X
crypto map Outside_map 4 set transform-set ESP-AES-128-SHA
crypto map Outside_map 4 set reverse-route
crypto map Outside_map 5 match address Outside_5_cryptomap
crypto map Outside_map 5 set peer X.X.X.X
crypto map Outside_map 5 set transform-set ESP-AES-128-SHA
crypto map Outside_map 5 set reverse-route
crypto map Outside_map interface Outside
ASA5520STL01# sh run router
router eigrp 100
no auto-summary
distribute-list EIGRP_In_From_Core in interface inside
network X.X.X.X X.X.X.X
passive-interface default
no passive-interface inside
redistribute static route-map Redistribute_Connected_Tunnels
ASA5520STL01# sh run route-map
route-map Redistribute_Connected_Tunnels permit 1
match ip address Redistribute_Connected_Tunnels
Working great now!
Darren
Good to hear!
Please rate helpful posts....
