ASA 5525X Outside Configuration Confirmation
The below said access lists are enough to protect the outside interface in ASA 5525X ?
access-list outside line 36 extended deny tcp any any (hitcnt=846) 0x2a966e57
access-list outside line 37 extended deny udp any any (hitcnt=260) 0x6c301697
access-list outside line 38 extended deny ip any any (hitcnt=9898747) 0xfd0ffa4a
Kindly provide your input, thanks in advance.
Pravin Raj K
Pravin Raj K
Network Engineer
Yes, "ip" includes all ip-based protocols. You don't need udp and tcp in addition to that. But with your ACL you'll see separate statistics for udp and tcp which could be desired.
6 Replies 6
There is an implicit "deny any" at the end of the ACL. You only need these lines if you want to have drop-statistics for TCP, UDP and all other IP-traffic.
Thank you, can you pease confirm implicit deny option at the end of ACL???
Pravin Raj K
Network Engineer
here is a document that relates to Karsten's remarks:
Note: Although all ACLs contain an implicit deny statement, Cisco recommends use of an explicit deny statement, for example, deny ip any any. On most platforms, such statements maintain a count of the number of denied packets. This count can be displayed using the show access-list command.
Check the link below for reference:
Cisco Firewall Best Practices Guide
https://www.cisco.com/c/en/us/about/security-center/firewall-best-practices.html
Thank you Georg,
So I assume from your comments that  "access-list outside line 38 extended deny ip any any (Last Line)"
is enough to block any traffic that comes to outside interface.
Pravin Raj K
Network Engineer
Thank you so much, got the desired answer.
Pravin Raj K
Network Engineer
