Traceroute Command Question :)
Iluvnetwork
Level 3
Level 3
I learned that 'traceroute' command is pretty useful for troubleshooting. The problem is that some devices ignore ICMP request and I get requested timed out message instead of time exceeded message.
[traceroute google.com result]
 1  172.30.1.254 (172.30.1.254)  1.516 ms  0.814 ms  0.755 ms
 2  * * *
 3  112.188.8.9 (112.188.8.9)  5.512 ms  2.718 ms  3.140 ms
 4  112.188.2.69 (112.188.2.69)  1.974 ms  2.186 ms  1.795 ms
 5  112.174.58.93 (112.174.58.93)  3.461 ms
    112.174.58.109 (112.174.58.109)  3.448 ms
    112.174.58.117 (112.174.58.117)  5.564 ms
 6  112.174.11.106 (112.174.11.106)  2.546 ms
    112.174.7.2 (112.174.7.2)  3.212 ms  2.912 ms
 7  72.14.194.106 (72.14.194.106)  37.417 ms  41.917 ms
    72.14.194.194 (72.14.194.194)  70.367 ms
 8  * * *
 9  108.170.233.15 (108.170.233.15)  35.229 ms  35.214 ms  32.921 ms
10  nrt12s13-in-f206.1e100.net (172.217.25.206)  32.687 ms  32.940 ms  32.442 ms
1. If I get a requested timed out message for TTL=2 ICMP Request, how traceroute still works? The gateway router will forward the packet to the best path according to the routing table. If my gateway router forwards my TTL=2 ICMP Request (Should be 1 when the gateway forwards) and the next hop router ignores it, either traceroute stops or I should keep getting a requested timed out message generated by my ping.exe. How come I reached google within 10hops?
2. When my PC sends TTL = 5(could be 4) ICMP request, following is the result. There should be 1IP, but I see three IPs. Can anyone explain to me what is going on?
3. How come there are three RTT times?
4. I think RTT must keep increasing. But it seems like it also decreases when you look at 4 and 5. Why did it decrease?
5. So, did I reach google within 10hops or 8 hopes(10-2 requested timed out)?
Hell0
You usually find that this is a result of a firewall or router ACL negating a response to a traceroute, Mostly though you wont even be aware of all the routers your traceroute actually passes through, Due to something call ttl-propagation which can be and usually is disabled so you cannot see the ISP's internal network.
res
Paul
Kind Regards
Paul
