ASA Branch to Branch tunnel creation failures using OSPF at core site ASAs - unique scenario
gp1200x
Level 2
Level 2
I have multiple ASAs attached to a network core. The core controls all OSPF routing and provides the default route for all subnets. The ASAs at the core location participate in the OSPF routing and add their crypto remote subnets to the routing table along and update their routing tables from the core switch. Each of the ASAs has their own default route to the Internet and that overrides the default route published by the core switch. All remote site ASAs simply have a default route from the ISP and do not participate in the OSPF routing. The remote ASAs have a cypto map for interesting traffic that needs to reach the core subnets.
Here is a simplification of what I do....I pass voice and data to remote sites using a single ASA for both voice and data to a single ASA at the core switch...no issues and QOS works fairly well. For larger remote sites with heavy traffic we use two ASAs at a remote site and apply QOS to both still...one ASA goes to a voice ASA at the core site and one ASA goes to a data ASA at the core site...again no issues and works well. For remote sites with a single ASA the ISP provides the external IP using DHCP and the remote site always originates the branch to branch tunnel.
Here is where my issue is now. At some sites I want to use a single ASA for both voice and data but instead of having a single crypto to an ASA at the core for both voice and data traffic, I wanted to have two separate crypto maps to send voice to a voice ASA at the core and one crypto map to send data to a data ASA at the core. But when I create the crypto maps something different takes place in my routing. For some reason the remote site's external IP address is being imported into the core routing table at the core switch. Since I am trying to create to separate crypto tunnels via two distinct ASAs at the core, one of the tunnels will fail. This is because at the core one of the ASAs will think it needs to go back internally to reach the outside address of the remote ASA since it imported the route from the core switch, which had imported the route to the remote sites external IP address from the first ASA that had completed a tunnel to the remote site.
Now here is the weird issue. The external IP address of a remote site is never in the core routing table when ONLY one crypto map is created on the remote ASA. It is only when I add a second crypto map to another different ASA that this issue pops up. And it is reproducable over and over...not a fluke. As an example I show the two different cryptos below.
Below is the remote site ASA crypto map for connecting to a single ASA at the core location - the remote site ASAs' external IP address is never seen in the routing tables at the core location
crypto map DCNY 10 match address OCIS
crypto map DCNY 10 set pfs group5
crypto map DCNY 10 set connection-type originate-only
crypto map DCNY 10 set peer 173.150.173.125 173.150.173.123
crypto map DCNY 10 set transform-set MAX
crypto map DCNY 10 set security-association lifetime seconds 86300
crypto map DCNY 10 set security-association lifetime kilobytes 4608000
crypto map DCNY 50 ipsec-isakmp dynamic DYN-DCNY
crypto map DCNY interface outside
crypto isakmp identity address
crypto isakmp enable outside
Below is the same remote site but now trying to create two separate tunnels to two different ASAs at the core location....failure occurs...now the remote site ASAs' external IP address is imported into the cores routing table when the first branch to branch tunnel is made.....so only one tunnel will complete successfully so this scenario fails. The peers are addresses at the core location via different core ASAs.
crypto map DCNY 9 match address OCIS-Voice
crypto map DCNY 9 set pfs group5
crypto map DCNY 9 set connection-type originate-only
crypto map DCNY 9 set peer 105.40.157.26 105.40.157.27
crypto map DCNY 9 set transform-set MAX
crypto map DCNY 9 set security-association lifetime seconds 86300
crypto map DCNY 9 set security-association lifetime kilobytes 4608000
crypto map DCNY 10 match address OCIS-DATA
crypto map DCNY 10 set peer 174.250.171.125 175.50.171.123 204.130.200.200
Any ideas would be helpful...thanks
5 Replies 5
-->  For some reason the remote site's external IP address is being imported into the core routing table at the core switch.
With 'external' you mean what, the public IP address of the remote site ? What are you advertising into OSPF at the remote site ?
Post the configs of the core and remote site ASAs...
Yes I mean the public IP address of the remote ASA is being imported into the routing table of the core ASA and then pushed to the core switch for distribution. Remote ASAs do not run any routing protocol. They use DHCP and obtain their IP and default route from the ISP.
Core ASA config
hostname ASA-DC1
domain-name dcny.gov
enable password 8CM8MUrMx35VJZSB encrypted
passwd 8CM8MUrMx35VJZSB encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 17.100.171.125 255.255.255.0
ospf cost 800
ospf authentication-key OCIS
ospf database-filter all out
ospf authentication
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.42.199.150 255.255.255.240
ospf cost 100
ospf authentication
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
banner exec
banner exec
banner exec WARNING: Configuration changes are dynamic!
banner exec
banner exec WARNING: Violators are subject to dismissal and prosecution.
banner exec
banner login
banner login ****************************************************************
banner login * WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! *
banner login * Access to and use of this device and/or other devices is *
banner login * restricted to authorized users only. Unauthorized *
banner login * individuals attempting to access this device may be *
banner login * subject to prosecution. *
banner login
boot system disk0:/asa825-59-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
retries 10
name-server 10.42.196.36
name-server 4.2.2.1
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list External_in remark "External packets allowed in"
access-list External_in extended permit icmp any any echo-reply
access-list External_in extended permit icmp any any unreachable
access-list External_in extended permit icmp any any time-exceeded
access-list External_in extended permit icmp any any source-quench
access-list Internal_out remark "Allow outbound traffic"
access-list Internal_out extended permit ip any 10.0.0.0 255.0.0.0
access-list Internal_out extended permit ip any 172.22.0.0 255.255.0.0
access-list Internal_out extended permit udp any any eq biff
access-list Internal_out extended permit tcp any any eq pop3
access-list Internal_out extended permit tcp any any eq smtp
access-list Internal_out extended permit tcp any any eq https
access-list Internal_out extended permit tcp any any eq www
access-list Internal_out extended permit tcp any any eq domain
access-list Internal_out extended permit udp any any eq domain
access-list Internal_out extended permit tcp any any eq ftp
access-list Internal_out extended permit tcp any any eq ftp-data
access-list Internal_out extended permit tcp any any eq telnet
access-list Internal_out extended permit icmp any any
access-list Internal_out extended permit tcp any any gt 1024
access-list Internal_out extended permit udp any any gt 1024
access-list Internal_out extended permit tcp any any eq 465
access-list Internal_out extended permit tcp any any eq 993
access-list Internal_out extended permit tcp any any eq 995
access-list Internal_out extended permit tcp any any eq imap4
access-list Internal_out extended permit tcp any any eq ssh
access-list NONAT extended permit ip any 10.0.0.0 255.0.0.0
access-list NONAT extended permit ip any 172.22.0.0 255.255.0.0
access-list NONAT extended permit ip any 192.168.0.0 255.255.0.0
access-list SPLIT-TUNNEL remark "From secure network to VPN user"
access-list SPLIT-TUNNEL extended permit ip 10.0.0.0 255.0.0.0 any
access-list SPLIT-TUNNEL extended permit ip 172.22.0.0 255.255.0.0 any
access-list 999 extended permit ip any 172.22.0.0 255.255.0.0
access-list 999 extended permit ip 172.22.0.0 255.255.0.0 any
pager lines 24
logging enable
logging timestamp
logging buffer-size 1048576
logging asdm-buffer-size 512
logging console emergencies
logging monitor emergencies
logging buffered debugging
logging trap emergencies
logging history informational
logging asdm emergencies
logging facility 21
logging device-id hostname
no logging message 106023
no logging message 401004
mtu outside 1500
mtu inside 1500
ip local pool vpn-pool 10.42.199.151
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit name idsattack attack action alarm drop reset
ip audit name idsinfo info action alarm
ip audit interface outside idsinfo
ip audit interface outside idsattack
ip audit interface inside idsinfo
ip audit interface inside idsattack
ip audit info action alarm drop reset
ip audit attack action alarm drop reset
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any unreachable outside
icmp permit any echo-reply outside
icmp permit any time-exceeded outside
icmp permit any echo-reply inside
icmp permit any unreachable inside
icmp permit any echo inside
icmp permit any time-exceeded inside
asdm image disk0:/asdm-761.bin
asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
access-group External_in in interface outside
access-group Internal_out in interface inside
router ospf 100
router-id 10.42.199.150
network 10.0.0.0 255.0.0.0 area 0
log-adj-changes
redistribute static metric 111 subnets
route outside 0.0.0.0 0.0.0.0 173.50.171.1 1
route inside 0.0.0.0 0.0.0.0 10.42.199.145 tunneled
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication serial console LOCAL
aaa authentication enable console LOCAL
aaa authorization command LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
snmp-server host inside 10.42.196.238 community sico
snmp-server host inside 10.42.202.140 community sico
snmp-server location ASA-DC1
snmp-server contact Grant Hait
snmp-server community sico
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
sysopt connection preserve-vpn-flows
auth-prompt prompt Please provide proper credentials for Authentication.
auth-prompt accept Thank you. Your credentials have been verified for access.
auth-prompt reject Rejected! Your credentials are invalid.
service resetinbound
service resetoutside
crypto ipsec transform-set MAX esp-aes-256 esp-sha-hmac
crypto ipsec transform-set MED esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 86300
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYN-DCNY 40 set pfs group5
crypto dynamic-map DYN-DCNY 40 set transform-set MAX
crypto dynamic-map DYN-DCNY 40 set security-association lifetime seconds 86300
crypto dynamic-map DYN-DCNY 40 set security-association lifetime kilobytes 4608000
crypto dynamic-map DYN-DCNY 40 set reverse-route
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 20
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
crypto isakmp disconnect-notify
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 10
ssh scopy enable
ssh 100.40.222.0 255.255.255.240 outside
ssh 204.130.200.0 255.255.255.0 outside
ssh 100.40.157.24 255.255.255.248 outside
ssh 173.50.171.0 255.255.255.192 outside
ssh 64.72.67.128 255.255.255.224 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 10
console timeout 30
management-access inside
priority-queue outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp authenticate
ntp server 10.42.199.145 source inside prefer
tftp-server inside 10.42.205.106 /
webvpn
group-policy ocisadmingroup internal
group-policy ocisadmingroup attributes
dns-server none
vpn-idle-timeout 60
vpn-session-timeout 480
vpn-tunnel-protocol IPSec
pfs enable
ipsec-udp enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SPLIT-TUNNEL
username dutchess password izZSjKs6QEroqcJJ encrypted privilege 15
username verizon password mmJzopA9lPGcK6W6 encrypted privilege 15
username 412eb8a0 password 0SRHIJRFeU2QiC00 encrypted privilege 15
username pwalker password 0Ja1AJcVnhJ8TNwh encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 10
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key DCNY#131485506#OCIS
isakmp keepalive threshold 20 retry 3
tunnel-group DefaultRAGroup general-attributes
authentication-server-group (outside) LOCAL
tunnel-group DefaultWEBVPNGroup general-attributes
tunnel-group DefaultWEBVPNGroup ipsec-attributes
tunnel-group ocisadmingroup type remote-access
tunnel-group ocisadmingroup general-attributes
address-pool vpn-pool
default-group-policy ocisadmingroup
tunnel-group ocisadmingroup ipsec-attributes
class-map Voice
class-map VOIP-TRAFFIC
match access-list 999
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
id-randomization
id-mismatch action log
policy-map QOS-TRAFFIC-OUT
class VOIP-TRAFFIC
class class-default
shape average 35000000
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
inspect ctiqbe
inspect icmp
inspect icmp error
inspect ils
inspect ipsec-pass-thru
inspect mgcp
inspect pptp
inspect snmp
inspect ip-options
policy-map tets
class Voice
policy-map PRIORITY-POLICY
class VOIP-TRAFFIC
priority
service-policy global_policy global
privilege cmd level 1 mode exec command disable
privilege cmd level 10 mode exec command ping
privilege show level 10 mode exec command running-config
privilege show level 10 mode exec command capture
privilege show level 2 mode exec command interface
privilege show level 2 mode exec command ip
privilege show level 10 mode exec command isakmp
privilege show level 10 mode exec command ipsec
privilege show level 2 mode exec command blocks
privilege show level 2 mode configure command interface
privilege show level 10 mode configure command logging
privilege show level 2 mode configure command ip
privilege show level 10 mode configure command isakmp
privilege show level 10 mode configure command ipsec
prompt hostname context
no call-home reporting anonymous
Remote site ASA config
hostname HEALTH-MSt
names
 description outside
 switchport access vlan 500
 description Data
 switchport access vlan 10
 description Data
 description Data
interface Ethernet0/4
 description Wireless
interface Ethernet0/5
 description Voice
interface Ethernet0/6
 description Voice
 switchport access vlan 172
interface Ethernet0/7
 description Voice
interface Vlan10
 nameif Data
 security-level 100
 ip address 10.42.198.145 255.255.255.248
interface Vlan172
 nameif Voice
 security-level 100
 ip address 172.22.198.145 255.255.255.248
interface Vlan500
 nameif outside
 security-level 0
 dhcp client update dns
 ip address 100.40.222.10 255.255.255.0
banner exec
banner exec
banner login
banner login
ftp mode passive
 retries 10
access-list OCIS remark "Packet for VPN tunnel"
access-list OCIS extended deny ip any host 10.42.198.150
access-list OCIS extended deny ip host 10.42.198.150 any
access-list OCIS extended permit ip 172.22.198.144 255.255.255.248 any
access-list OCIS extended permit ip 10.42.198.144 255.255.255.248 any
access-list OCIS-Voice extended permit ip 172.22.198.144 255.255.255.248 any
access-list OCIS-Data remark "Packet for VPN tunnel"
access-list OCIS-Data extended deny ip any host 10.42.198.150
access-list OCIS-Data extended deny ip host 10.42.198.150 any
access-list OCIS-Data extended permit ip 10.42.198.144 255.255.255.248 any
access-list NONAT remark "Packets not natted"
access-list tcp-traffic extended permit tcp any any
access-list tg-nonVoice-out extended permit ip 10.42.198.144 255.255.255.248 any
access-list tg-nonVoice-out extended permit ip 172.22.198.144 255.255.255.248 an        y
access-list tg-nonVoice-in extended permit ip any 10.42.198.144 255.255.255.248
access-list tg-nonVoice-in extended permit ip any 172.22.198.144 255.255.255.248
access-list IP-ANY extended permit ip any any
access-list Voice-In extended permit ip any 172.22.198.144 255.255.255.248
pager lines 24
logging timestamp
logging console debugging
logging buffered emergencies
logging history emergencies
logging facility 21
mtu Data 1500
mtu Voice 1500
mtu outside 1500
ip local pool vpn-pool 10.42.198.150
ip audit interface Data idsinfo
ip audit interface Data idsattack
ip audit interface Voice idsinfo
ip audit interface Voice idsattack
no failover
icmp permit any echo-reply Data
icmp permit any unreachable Data
icmp permit any echo Data
icmp permit any time-exceeded Data
icmp permit any echo-reply Voice
icmp permit any unreachable Voice
icmp permit any echo Voice
icmp permit any time-exceeded Voice
asdm image disk0:/asdm-771-150.bin
asdm history enable
arp timeout 14400
nat-control
nat (Data) 0 access-list NONAT
nat (Data) 1 10.42.198.144 255.255.255.248
nat (Voice) 0 access-list NONAT
nat (Voice) 1 172.22.198.144 255.255.255.248
route outside 0.0.0.0 0.0.0.0 100.40.222.1 1
http server enable
http 0.0.0.0 0.0.0.0 Data
http 10.0.0.0 255.0.0.0 Data
snmp-server location DACC
snmp-server community *****
crypto ipsec security-association replay window-size 1024
crypto dynamic-map DYN-DCNY 40 set security-association lifetime kilobytes 46080        00
crypto map DCNY 5 match address OCIS-Data
crypto map DCNY 5 set pfs group5
crypto map DCNY 5 set connection-type originate-only
crypto map DCNY 5 set peer 17.100.171.125
crypto map DCNY 5 set transform-set MAX
crypto map DCNY 5 set security-association lifetime seconds 86300
crypto map DCNY 5 set security-association lifetime kilobytes 4608000
crypto map DCNY 9 set peer 100.50.157.55
 encryption aes-256
 hash sha
 group 5
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 30
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 65535
 encryption 3des
 hash sha
 group 2
 lifetime 86400
no crypto isakmp nat-traversal
telnet 0.0.0.0 0.0.0.0 Data
telnet 0.0.0.0 0.0.0.0 Voice
telnet timeout 10
ssh scopy enable
ssh 0.0.0.0 0.0.0.0 Data
ssh 0.0.0.0 0.0.0.0 Voice
ssh timeout 10
console timeout 30
management-access Data
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 28800
dhcpd ping_timeout 2000
dhcpd domain dcny.info
dhcpd address 10.42.198.147-10.42.198.149 Data
dhcpd dns 10.42.196.36 10.42.192.92 interface Data
dhcpd wins 10.42.196.36 10.42.192.92 interface Data
dhcpd lease 86400 interface Data
dhcpd ping_timeout 2000 interface Data
dhcpd domain dcny.gov interface Data
dhcpd enable Data
dhcpd address 172.22.198.147-172.22.198.150 Voice
dhcpd dns 10.42.196.36 10.42.192.92 interface Voice
dhcpd wins 10.42.196.36 10.42.192.92 interface Voice
dhcpd lease 86400 interface Voice
dhcpd ping_timeout 2000 interface Voice
dhcpd domain dcny.gov interface Voice
dhcpd option 150 ip 172.22.97.3 172.22.196.3 interface Voice
dhcpd enable Voice
  queue-limit   938
  tx-ring-limit 10
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 averag        e-rate 200
ntp authenticate
ntp server 10.42.196.1 source Data prefer
tftp-server Data 10.42.205.106 /
webvpn
 pre-shared-key *****
tunnel-group DefaultRAGroup ipsec-attributes
tunnel-group 96.233.200.42 type ipsec-l2l
tunnel-group 96.233.200.42 ipsec-attributes
tunnel-group 96.233.200.34 type ipsec-l2l
tunnel-group 96.233.200.34 ipsec-attributes
tunnel-group 64.72.67.142 type ipsec-l2l
tunnel-group 64.72.67.142 ipsec-attributes
tunnel-group 96.233.200.44 type ipsec-l2l
tunnel-group 96.233.200.44 ipsec-attributes
tunnel-group 100.40.157.26 type ipsec-l2l
tunnel-group 100.40.157.26 ipsec-attributes
tunnel-group 100.40.157.27 type ipsec-l2l
tunnel-group 100.40.157.27 ipsec-attributes
tunnel-group 173.50.171.125 type ipsec-l2l
tunnel-group 173.50.171.125 ipsec-attributes
tunnel-group 17.100.171.125 type ipsec-l2l
tunnel-group 17.100.171.125 ipsec-attributes
tunnel-group 204.130.200.200 type ipsec-l2l
tunnel-group 204.130.200.200 ipsec-attributes
class-map TG-NonVoice-Out
 match access-list tg-nonVoice-out
class-map TG-Voice-Out
 match dscp ef
 match tunnel-group 100.40.157.26
class-map Voice-In
 match access-list Voice-In
class-map TG-Voice-In
 match dscp ef
class-map TCP-Traffic
 match access-list tcp-traffic
class-map policing_traffic
 match access-list IP-ANY
class-map TG-NonVoice-In
 match access-list tg-nonVoice-in
class-map Voice-Out
 match dscp ef
class-map Voice-IN
 match dscp ef
 parameters
  message-length maximum client auto
  id-randomization
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
policy-map qos
 class TG-Voice-Out
  priority
 class TG-Voice-In
  police input 2000000
 class TG-NonVoice-Out
  police output 15000000
 class TG-NonVoice-In
  police input 30000000
 class TCP-Traffic
  police input 35000000
 class class-default
  police output 2000000
  police input 5000000
policy-map Policing
 class Voice-Out
  priority
 class Voice-In
  police input 6000000 1125000
 class policing_traffic
  police input 135000000 25312500
  police output 135000000 25312500
privilege cmd level 1 mode cache command disable
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DD        CEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
so this is the public IP address that gets into OSPF and redistributed ?
-->  ip address 100.40.222.10 255.255.255.0
If the remote site doesn't even participate in OSPF...it is strange that the core even knows about this network. I'll need to lab this up...
Yes you are correct. It is the outside IP address of the remote ASA that is getting imported into the core site ASA and the remote sites have no OSPF routing taking place.
I have probably a hundred tunnels to our core and this only showed up for the first time when I tried to install the two separate crypto maps on the remote ASA. If you delete the crypto map for OCIS-Voice (or OCIS-Data) and reboot the remote ASA, that remote IP external address never gets imported into the core routing table (which is what I want).
I have seen the remote site IP address get imported from both the core ASAs at the core. I looked the config over many times and haven't seen any reason for it.....maybe I am shooting a code bug for that level???
THANKS
I also just tested code version 9.2.3 on the remote site ASA with the same type of setup and it had the same issue at the core site with the importing of the remote site external IP address. Core sites were still running 8.2.59   I may try to update to 9.2.3 but they are production so it is difficult.
