DHCP from ISP not working with NAT
ricky levesque
Hello All,
I have an issue with an ISR router i'm setting up on my home lab.
my ISP provides IP addresses on a vlan interface.
when my router is configured with this Dot1Q interface, it gets an IP from the ISP DHCP server.
when i configure NAT on the outside interface, (ip nat outside) i can no longer receive an IP from the DHCP server for that interface.
here are my configs:
outside interface:
interface GigabitEthernet0/0/0.35
description ISP_vlan_35
encapsulation dot1Q 35
ip address dhcp
ip nat outside
NAT configs:
ip nat inside source list 100 interface GigabitEthernet0/0/0.35 overload
ACL config:
access-list 100 permit ip any any
default route:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0.35 dhcp
if i get an IP address and configure NAT afterwards, i can get on the internet from internal devices... until the DHCP lease expires.
any ideas on why i'm not getting an IP when i configure NAT-Outside?
thanks in advances for your help and attemtion to my question
Deepak Kumar
If I am getting your point correctly. As I am getting that this issue with NATTing. It is not happing if you will connect ISP after configuring the NAT.
Please share some output:
sho ip nat statistics
Show IP nat translation
Show ip route
show ip access-list
But same time, you can try to edit ACL 100 with a specific LAN subnet.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
johnd2310
Level 8
Level 8
What router and ios version are you running?
John
**Please rate posts you find helpful**
router is an ISR 1111
curently running: IOS version 16.06.04
also tried: 16.07.01
Deepak Kumar
Show ip route
show ip access-list
Deepak Kumar
Deepak Kumar,
Thank you Deepak kumar
changing the ACL to the specific subnet has fixed the issue.
i'll have to find out why the ACL was stopping the DHCP traffic.
thanks for your help.
This really helped me too! I actually had "ip access-group 100 out" on the WAN side and this caused big problems. I was loosing hours of troubleshooting NAT..and then I just removed it...the more specified ACL did it for me too...WOW...what a relief...esp. running an ISR 1111x-8P at home..too good of a device to have considered defective or whatever have you...
