ASA nat configuration
getaway51
Level 2
Level 2
Hi , need help frm master to interpret the config below in ASA fw.many many thanks!
1)The NAT will happen whenever traffic flows from vlan-wlan->outside & vlan-mls->inside?
2)ASA will perform nat when doing nat configuration under "object network XXX"? not quite sure why nat config is done under object network object-172.10.254.0 & object network test-ip. Is this the normal way of doing nat?
nat (vlan-wlan,outside) dynamic interface
nat (vlan-mls,inside) static 172.16.1.5
5 Replies 5
Julio E. Moisa
Answer: It is basically a PAT, the host or network included on the object called: object-172.10.254.0 will be NATed to the IP address located under the outside interface. Basically the inside interface is vlan-wlan and the outside interface is called outside (vlan-wlan,outside), the info into the ( ) represents the inside and outside interface, ingress and egress.
Answer: The host included into the object called test-ip will be mapped to the IP address 172.16.1.5. The test-ip must be behind the vlan-mls nameif interfance (ingress) and the IP 172.16.1.5 will be NAT IP located at the inside nameif interface.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
1)why need to put "nat" config under "object network"?
2)Can use only this command? --> nat (vlan-wlan,outside) dynamic interface
or all "nat" config needs to happen under "object network"?
If you want all traffic originating from vlan-wlan to be translated when it goes out the outside interface then you would use this command
and if you want specifically traffic from 172.10.254.0 to be translated then you would use the object network approach.
Rick
Rick
nat (inside,any) source static net-10.1.1.0 net-10.1.1.0 destination static net-172.27.0.0 net-172.27.0.0 no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
Appreciate if anyone can help interpreting!!!
1)These 2 nat cmd. the first nat command means what? why is it source and dest is the same? Gt this kind of traffic in the network? I have trouble understand why ppl configure such cmds
2)the 2nd nat cmd will apply for the rest of all traffic other than source net-10.1.1.0? I mean if it doesn't hit the first nat source & dest match?
The first nat is typically used when there is a site to site vpn. The vpn would be carrying traffic between 10.1.1.0 and 172.27.0.0. With a site to site vpn you typically do not want to translate the traffic going through the vpn. The other side of the vpn expects to see traffic with a source address of 10.1.1.x and not have that traffic translated so the source address would be the ASA interface. So basically what this command is saying is that 10.1.1.0 translates to 10.1.1.0 and 172.27.0.0 translates to 172.27.0.0.
The second nat command will translate all other traffic originating from the inside interface and going through the outside interface.
Rick
Rick
