01-19-2019 07:28 AM
Hi I am just trying to find my way around an asa. I would like to forward a port.
I have
wan ,pfsense gw on 192.168.1.1 and internal network on the 192.168.1. range.
Then I have the asa which has the 192.168.1.1 as its gateway and its wan ip is 192.168.1.250 and on the other side of the asa a range of 192.168.2.*
The 192.168.2.* can access the internet fine bit I would like the 192.168.1.* range and the internet to access an internal server on 192.168.2.7 behind the asa.
I ran
object network Internal_linux_Server
ciscoasa(config)# object network Internal_linux_Server
ciscoasa(config-network)# network-object host 192.168.2.7
exit
static (inside,outside) tcp interface 22 192.168.2.7 22 netmask 255.255.255.255
access-list Outside_access_in extended permit tcp any object Internal_linux_Server eq 22
access-group Outside_access_in in interface outside
ciscoasa(config)# show nat
NAT policies on Interface inside:
match tcp inside host 192.168.2.7 eq 22 outside any
static translation to 192.168.1.250/22
translate_hits = 0, untranslate_hits = 21
match ip inside any inside any
dynamic translation to pool 1 (No matching global)
translate_hits = 0, untranslate_hits = 0
match ip inside any outside any
dynamic translation to pool 1 (192.168.1.250 [Interface PAT])
translate_hits = 2988, untranslate_hits = 544
match ip inside any _internal_loopback any
any pointers please. I suspect I am way off
Solved! Go to Solution.
01-19-2019 11:04 AM
Turns out these 3 lines did what I wanted perfectly
access-list outside_access_in extended permit tcp any interface outside eq 3389
static (inside,outside) tcp interface 3389 192.168.1.10 3389 netmask 255.255.255.255
access-group outside_access_in in interface outside
http://remotesupportsoftware.blogspot.com/2008/10/configure-rdp-port-forwarding-on-cisco.html
01-19-2019 11:04 AM
01-19-2019 01:14 PM
Thanks for posting the solution. It may help someone else one day.
