01-19-2019 02:17 AM - edited 03-05-2019 11:11 AM
Hello Expert,
I have some old 2811 and two 3945 routers in my network and would like to out fit them with Wan cards to do allow pppoe connection to other sites.Note this is just a short term arrangement they will all be replace by the last quarter of the year.I was looking at a 2 or 4 port Hwic card. Could you please advise if the card can be use or if not kindly suggest the correct type of card purchase?
I should mention for 2811 router wan interface is use and for the 3945 router all the wan interfaces are in use.
The propose card will be use for wan redundancy to another service provider via PPPOE.
Solved! Go to Solution.
01-19-2019 02:31 AM
the HWIC-1ADSL and the HWIC-2ADSL are compatible with both the 2811 and the 3945 routers...
01-19-2019 02:31 AM
01-19-2019 07:21 AM - edited 01-19-2019 11:56 AM
Hello Georg,
Thanks for the reply, I am just looking for a card that can operate the same way like the integrated ge0/0 and g/e0/1 (wan) on the router.
01-19-2019 12:00 PM
