ASA Routing INSIDE, DMZ, OUTSIDE
woodjl16501
I need some help, I have my web server on my DMZ interface, but that it doesn't have access to the internet. Unable to the get a ping from inside to the DMZ.  Not sure what I am missing, my goal is to have access to the internet from the DMZ and my inside subnet access to the DMZ and Internet.
192.168.10.0/24 > Inside
192.168.12.0/28 > DMZ
IP setting on Web Server
192.168.12.2 > WebServer Connected directly to F0/3 on the ASA
255.255.255.250 > Netmask
192.168.10.1 > Gateway
ASA Version 9.1(6)
Current Config:
ASAHome# show run
: Saved
: Serial Number: JMX1302L1QL
: Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
ASA Version 9.1(6)
hostname ASAHome
domain-name twinkie710.ddns.net
enable password 7rhyV6SC2srI9RYo encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
ip local pool VPNUsers 192.168.11.10-192.168.11.50 mask 255.255.255.192
interface Ethernet0/0
 nameif outside
 security-level 0
 ip address dhcp setroute
interface Ethernet0/1
 nameif inside
 security-level 100
 ip address 192.168.10.1 255.255.255.0
interface Ethernet0/2
 nameif DMZ
 security-level 0
 ip address 192.168.12.1 255.255.255.240
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 100
 ip address 192.168.11.1 255.255.255.252
boot system disk1:/asa916-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
 name-server 192.168.10.15
 name-server 8.8.8.8
 name-server 4.2.2.2
 name-server 8.8.4.4
same-security-traffic permit intra-interface
object network inside-subnet
 subnet 192.168.10.0 255.255.255.0
object network dmz-subnet
 subnet 192.168.12.0 255.255.255.240
object network webserver-external-ip
 host 192.168.12.10
 host 192.168.12.2
object network dns-server
 host 192.168.10.15
object network LAN
object network DMZ
object network NETWORK_OBJ_192.168.11.0_26
 subnet 192.168.11.0 255.255.255.192
object network VPNPOOL
access-list outside_acl extended permit tcp any object webserver eq www
access-list dmz_acl extended permit udp any object dns-server eq domain
access-list dmz_acl extended deny ip any object inside-subnet
access-list dmz_acl extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image disk0:/asdm-751.bin
asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static inside-subnet inside-subnet destination static VPNPOOL VPNPOOL no-proxy-arp route-lookup
 nat (inside,outside) dynamic interface
 nat (DMZ,outside) dynamic interface
 nat (DMZ,outside) static webserver-external-ip service tcp www www
nat (outside,outside) after-auto source dynamic VPNPOOL interface
access-group outside_acl in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.10.0 255.255.255.0 inside
snmp-server group Admins v3 priv
snmp-server host inside 192.168.10.11 community *****
snmp-server host inside 192.168.10.12 community *****
snmp-server host inside 192.168.10.2 community *****
snmp-server location Office
snmp-server contact Jonathan
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
 protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map DMZ_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map DMZ_map interface DMZ
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto ca trustpool policy
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 enable outside client-services port 443
crypto ikev1 enable outside
crypto ikev1 enable inside
crypto ikev1 enable DMZ
crypto ikev1 policy 10
 authentication crack
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 20
 authentication rsa-sig
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 30
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 40
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 50
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 60
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 70
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 80
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 90
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 100
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 110
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 120
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 130
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 140
 encryption des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 150
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh stricthostkeycheck
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access management
dhcpd address 192.168.10.50-192.168.10.200 inside
dhcpd dns 192.168.10.15 interface inside
dhcpd domain twinkie710.ddns.net interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 38.229.71.1 source outside
ntp server 209.208.79.69 source outside
ntp server 108.59.2.24 source outside
ntp server 45.79.111.114 source outside prefer
group-policy VPN_Users internal
group-policy VPN_Users attributes
 dns-server value 192.168.10.15 8.8.8.8
 vpn-tunnel-protocol ikev1
 split-tunnel-policy tunnelall
 default-domain value twinkie710.ddns.net
 split-tunnel-all-dns enable
username woodjl1650 password IYD1wu7sEjGmHAyj encrypted privilege 15
tunnel-group VPN_Users type remote-access
tunnel-group VPN_Users general-attributes
 address-pool VPNUsers
 default-group-policy VPN_Users
tunnel-group VPN_Users ipsec-attributes
 ikev1 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
 class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:e6125cf0a468ec6ad3f580aa3d861ffa
: end
Yes you have that error because you're using port https on your asa for asdm and vpn.
You have 2 solutions:
1. Use another port for your server like 8443 redirected internally to your server port 443
Or
2. Change your ASA port.
For accessing your dmz through VPN you'll need to add the following command:
nat (DMZ,outside) source static dmz-subnet dmz-subnet destination static VPNPOOL VPNPOOL no-proxy-arp route-lookup
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
18 Replies 18
Francesco Molino
You've setup a deny on your acl for dmz_acl. For testing purpose, let's remove it and when everything will work you can add acl to filter access from inside to dmz.
For internet you're missing a command.
Here the config you should apply:
no access-list dmz_acl line 2 extended deny ip any object inside-subnet
access-list dmz_acl line 2 extended permit ip any object inside-subnet
access-group dmz_acl in interface DMZ
same-security-traffic permit inter-interface
Francesco
Ok, so I had a power outage, and no UPS. I lost my working config from the earlier post.  I removed and added what you suggested, but I can't ping from my laptop on the 192.168.10.0 subnet to the DMZ sever on 192.168.12.0 subnet.
What else am I missing?  Thanks again for the help and sorry about the config change.  I have a back up now... lesson learned.
Let's assume your laptop has IP 192.168.10.2 and server has IP 192.168.12.2.. on the below command change IPs with real one and paste the output:
1. packet-tracer input inside icmp 192.168.10.2 8 0 192.168.12.2
2. packet-tracer input DMZ icmp 192.168.12.2 8 0 192.168.10.2
Francesco
Attached is the output.
I didn't saw it on your config but you've a nat statement issue:
nat (DMZ,inside) after-auto source dynamic any interface
I guess you wanted to type:
nat (DMZ,outside) after-auto source dynamic any interface
Remove the nat DMZ to inside and add nat DMZ to outside and test it back
Francesco
Here are the results after making that modification above.  I still don't get a reply from the ping test on my laptop, could that just be the ASA denying ICMP requests?
Could you paste your config?
If you changed the nat statement it should work. I've tested your config.
Also your 1st packet-trace isn't good:
packet-tracer input inside icmp 192.168.12.2 8 0 192.168.10.129
You need to do:
packet-tracer input DMZ icmp 192.168.12.2 8 0 192.168.10.129
Francesco
Gotacha ya, overlooked that.
Good news, my DMZ server has internet access, but I still can't SSH into it from the 192.168.10.0 subnet.
Updated Packet Tracer Info and Config are attached.
What is your server IP in the DMZ zone?
Could you run the below command and paste the output in a txt file? (change IP addresses if they aren't correct)
packet-tracer input inside tcp 192.168.10.129 22 192.168.12.2 22
Francesco
I received these errors when apply the NAT rules:
ASAHome# config t
ASAHome(config)# object network webserver-HTTP
ASAHome(config-network-object)# host 192.168.12.2
ASAHome(config-network-object)# nat (DMZ,outside) static 68.102.214.123 servic$
ERROR: Address 68.102.214.123 overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
ASAHome(config-network-object)# object network webserver-HTTPS
If you have only 1 public IP then replace YOUR-PUBLIC-IP by INTERFACE
Francesco
I get this error when applying the HTTPS
ERROR: NAT unable to reserve ports.
Current config attached
Unable to access from outside of network (tested with iPhone on LTE, no WiFi)
Or
Francesco
How would I redirect so if I access via the VPN from the outside I can access my server via my IP and port 8443?
Sorry, still newish to this.  Thanks for your help.
