ASA routing
ashz14387
My ASA configuration
ASA Version 8.4(2)
hostname ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
nameif outside
security-level 0
ip address 172.168.1.2 255.255.255.0
interface GigabitEthernet1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet2
nameif INSIDE
security-level 100
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet3
nameif DMZ
security-level 90
ip address 20.20.20.1 255.255.255.0
ftp mode passive
access-list INSIDE extended permit icmp any any
access-list INSIDE extended permit icmp any any echo-reply
pager lines 24
mtu outside 1500
mtu INSIDE 1500
mtu DMZ 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group INSIDE in interface INSIDE
access-group INSIDE in interface DMZ
router ospf 1
router-id 3.3.3.3
network 10.10.10.0 255.255.255.0 area 0
network 11.11.11.0 255.255.255.0 area 0
network 20.20.20.0 255.255.255.0 area 1
network 21.21.21.0 255.255.255.0 area 1
log-adj-changes
redistribute static
route outside 0.0.0.0 0.0.0.0 172.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:0d97b54f91d2b923aba6434d3e066395
: end
ASA#
My R7 config
version 15.2
hostname R7
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
duplex full
interface FastEthernet1/0
ip address 11.11.11.1 255.255.255.0
duplex full
interface FastEthernet2/0
no ip address
shutdown
duplex full
interface FastEthernet3/0
no ip address
shutdown
duplex full
interface FastEthernet4/0
no ip address
shutdown
duplex full
router ospf 1
router-id 1.1.1.1
redistribute static
network 10.10.10.0 0.0.0.255 area 0
network 11.11.11.0 0.0.0.255 area 0
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip route 11.11.11.0 255.255.255.0 10.10.10.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
My R8 config,
version 15.2
hostname R8
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 20.20.20.2 255.255.255.0
duplex full
ip address 21.21.21.1 255.255.255.0
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
router ospf 1
router-id 2.2.2.2
redistribute static
network 20.20.20.0 0.0.0.255 area 1
network 21.21.21.0 0.0.0.255 area 1
network 0.0.0.0 255.255.255.255 area 1
no ip http server
ip route 0.0.0.0 0.0.0.0 20.20.20.1
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
 i am unable to ping the windows-server from the firefox why?
Kindly provide your assistance Thanks in advance.
Hi @ashz14387
 Can I see "show ip route" from devices ?  If you run tracert from windows to firefox where does it stops?
For R7,
S* 0.0.0.0/0 [1/0] via 10.10.10.1
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
O IA 2.2.2.2 [110/12] via 10.10.10.1, 01:17:15, FastEthernet0/0
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, FastEthernet0/0
L 10.10.10.2/32 is directly connected, FastEthernet0/0
11.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 11.11.11.0/24 is directly connected, FastEthernet1/0
L 11.11.11.1/32 is directly connected, FastEthernet1/0
20.0.0.0/24 is subnetted, 1 subnets
O IA 20.20.20.0 [110/11] via 10.10.10.1, 01:17:10, FastEthernet0/0
21.0.0.0/24 is subnetted, 1 subnets
O IA 21.21.21.0 [110/12] via 10.10.10.1, 01:17:10, FastEthernet0/0
For R8,
S* 0.0.0.0/0 [1/0] via 20.20.20.1
O IA 1.1.1.1 [110/12] via 20.20.20.1, 01:17:42, FastEthernet0/0
C 2.2.2.2 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
O IA 10.10.10.0 [110/11] via 20.20.20.1, 01:17:42, FastEthernet0/0
11.0.0.0/24 is subnetted, 1 subnets
O IA 11.11.11.0 [110/12] via 20.20.20.1, 01:17:42, FastEthernet0/0
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.20.20.0/24 is directly connected, FastEthernet0/0
L 20.20.20.2/32 is directly connected, FastEthernet0/0
21.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 21.21.21.0/24 is directly connected, FastEthernet1/0
L 21.21.21.1/32 is directly connected, FastEthernet1/0
For ASA,
Inside,
O 1.1.1.1 255.255.255.255 [110/11] via 10.10.10.2, 1:18:22, INSIDE
C 10.10.10.0 255.255.255.0 is directly connected, INSIDE
O 11.11.11.0 255.255.255.0 [110/11] via 10.10.10.2, 1:18:22, INSIDE
Outside,
C 172.168.1.0 255.255.255.0 is directly connected, outside
S* 0.0.0.0 0.0.0.0 [1/0] via 172.168.1.1, outside
DMZ,
O 2.2.2.2 255.255.255.255 [110/11] via 20.20.20.2, 1:19:03, DMZ
O 21.21.21.0 255.255.255.0 [110/11] via 20.20.20.2, 1:19:03, DMZ
C 20.20.20.0 255.255.255.0 is directly connected, DMZ,
Traceroute from Firefox and windows stops once it reaches ASA
All seems ok to me.  I would remove the security level on the asa inside and dmz interfaces just to make sure this is the ASA denying the traffic or not.
Thanks it works, i have configured the security level as 100 for both INSIDE & DMZ and i forgot to include inter-traffic command.
