ASA to ASA Site2Site Traceroute
Lee Dress
Hey folks,
We are converting our offices from MPLS to VPN Site2Site tunnels.
the tunnels are all operating properly with all traffic going in both directions.
Our issue is with Traceroute between sites.
On MPLS, everything replies during a traceroute. Between the ASA devices, I can get the "internal" one (local to the site) to respond, but not the "external" one (at the far end)
I have added the following according to what I can find on the internet about this issue:
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in remark ICMP type 3 for Cisco and Linux
access-list outside_access_in extended permit icmp any any unreachable
access-group outside_access_in in interface outside
then:
policy-map global_policy
class class-default
set connection decrement-ttl
and:
icmp unreachable rate-limit 10 burst-size 5
The issue I end up with is that the remote ASA doesn't show up in the list
See this trace:
tracert 192.168.26.11
  1    <1 ms    <1 ms    <1 ms  mwspcoresw1.mycompany.com [192.168.3.251]
  2    <1 ms    <1 ms    <1 ms  router.mycompany.com [192.168.3.253]
  3    <1 ms    <1 ms    <1 ms  asa_inside.mycompany.com [172.16.100.2]
  4     *        *        *     Request timed out.
  5    84 ms    86 ms    83 ms  192.168.26.11
I'm assuming the request timed out is the remote end ASA.
it happens exactly the same way from either site
any ideas?
luckymike33
Hi Idress,
The problem is the ASA doesn't behave exactly like a router when it comes to traceroute, because it doesn't decrement the icmp ttl, it therefore doesn't trigger an icmp-time exceeded.
Under the global policy, you need to enter the following command
class class-default
Very best wishes
Mike
set connection decrement-ttl is part of my config.
the local ASA responds, just not the remote one.
it happens in both directions.  from NJ to remote, or remote to NJ. the "local" asa responds, but not the remote one.
 1     1 ms    <1 ms    <1 ms  nj_coresw [192.168.3.251]
 2    <1 ms    <1 ms    <1 ms  nj_router [192.168.3.253]
 3    <1 ms    <1 ms    <1 ms  nj_asa_inside [172.16.100.2]
 4     *        *        *     Request timed out. <--I assume the is the remote ASA
 5   143 ms   139 ms   139 ms  192.168.25.11 <-- this is what I was trying to trace to.
