ASA to Router interfaces
Emil Naklicki
I have a simple network configuration  ISP==>Router==>ASA==>L3 Core. I am trying to add another link from my router to my ASA for DMZ and a secondary ISP. I do not want to add physical links as I would have to purchase another NIM for my router. In order to simply uses the current physical topology, do I simply create sub interfaces between my router and ASA? Example
Router Gi0/0.10 ==ASA Gi1/1.10 vlan 10
Router Gi0/0.20 ==ASA Gi1/1.10 vlan 20
Router Gi0/0.30 ==ASA Gi1/1.10 vlan 30
Is there any downsides and/or security concerns  to using sub-interfaces for this kind of topology. Also, is there any better way of handling this kind of topology without the need for additional physical ports?
For sure, vlan and subinterface is a good and flexible solution.
If your asa supports context, you can consider to use a virtual context for the new link. In this way you can have a virtual dedicated firewall.
About security, you can use ACL on your subinterface.
Regards.
Regards.
Thanks for the quick reply. Context would be over kill for what I'm trying to do. I think the sub-interface route is the way I'll go.
