ASA VTI VPN redistibuting Static route over EIGRP
ricardo.docchio
Hi everyone
I'm having an issue when i try to redistribute a static route that is known from a VTI interface to the EIGRP process. The route appears in the table and is working for the devices that have the ASA as gateway but when i add it to the prefix list that matches the redistribution route-map it just doesnt work as the other static routes configured for a physical or sub interface.
Working route: route OUTSIDE 7.7.7.7 255.255.255.255 X.X.X.X 1
Non working route: route VPN_VTI 172.23.40.0 255.255.255.0 169.254.150.3 1
FW-CORE-MULTIFI-ASA5545-SITE1/pri/act# sh run router eigrp
router eigrp 100
redistribute static route-map RM_REDISTRIBUCION_POR_EIGRP
prefix-list PL_REDISTRIBUCION_POR_EIGRP seq 40 permit 7.7.7.7/32
prefix-list PL_REDISTRIBUCION_POR_EIGRP seq 45 permit 172.23.40.0/24
route-map RM_REDISTRIBUCION_POR_EIGRP permit 10
match ip address prefix-list PL_REDISTRIBUCION_POR_EIGRP
FW-CORE-MULTIFI-ASA5545-SITE1/pri/act# sh route 172.23.40.0
Routing entry for 172.23.40.0 255.255.255.0
Known via "static", distance 1, metric 0
Redistributing via eigrp 100
Advertised by eigrp 100 route-map RM_REDISTRIBUCION_POR_EIGRP
Routing Descriptor Blocks:
* 169.254.150.3, via VPN_VTI
Route metric is 0, traffic share count is 1
In the "show eigrp topology" output the 172.23.40.0/24 route doesnt appear like the other one:
FW-CORE-MULTIFI-ASA5545-SITE1/pri/act# show eigrp topology | include 7.7.7.7
P 7.7.7.7 255.255.255.255, 1 successors, FD is 2816
FW-CORE-MULTIFI-ASA5545-SITE1/pri/act# show eigrp topology | include 172.23.40
On the neighbors it doesnt appear either in the eigrp topology table or routing table:
RT-AOFI-MULTIFI-4321-SITE1#sh ip eigrp topology | include 7.7.7.7
P 7.7.7.7/32, 1 successors, FD is 3072
RT-AOFI-MULTIFI-4321-SITE1#sh ip eigrp topology | include 172.23.40
RT-AOFI-MULTIFI-4321-SITE1#sh ip route | include 7.7.7.7
D EX 7.7.7.7
RT-AOFI-MULTIFI-4321-SITE1#sh ip route | include 172.23.40
ASA IOS version is 9.8(4)
Does anybody have seen this same issue?
17 Replies 17
Francesco Molino
On your asa, can you show the show route for 7.7.7.7 and also a show eigrp topology zero?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
curdubanbogdan
Turn off RRI and insert manually the static route pointing to vpn next hop.
sh route 7.7.7.7
Routing entry for 7.7.7.7 255.255.255.255
* X.X.X.X, via OUTSIDE
sh eigrp topology zero-successors
EIGRP-IPv4 Topology Table for AS(100)/ID(X.X.X.X)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 172.30.1.0 255.255.255.248, 0 successors, FD is Inaccessible
via A.A.A.A (28161024/28160768), INTA
via B.B.B.B (3072/2816), INTB
I dont see how disable Reverse Route Injection in a Routed Based VPN (VTI) like in a Policy based one, the VPN is up with the following ED so RRI might generate a problem in case it is enabled:
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
Richard Burts
It is clear that EIGRP marks this as inaccessible. My guess is that it is because of issues with the next hop specified in the static route:
How did you come up with that next hop?
What is the addressing on the VTI interface?
Rick
Rick
Hi Richard
Thanks for your reply, that next hop is an arbitrary IP in the same network as the Tunnel interface to route the traffic throught it, this address is not really configured in the remote end.
interface Tunnel50
nameif VPN_VTI
ip address 169.254.150.1 255.255.255.248 standby 169.254.150.2
tunnel source interface OUTSIDE
tunnel destination Y.Y.Y.Y
tunnel mode ipsec ipv4
tunnel protection ipsec profile PROFILE_VPN_VTI
Tunnel Interface is UP
Interface Tunnel50 "VPN_VTI", is up, line protocol is up
Hardware is Virtual Tunnel MAC address N/A, MTU 1500
IP address 169.254.150.1, subnet mask 255.255.255.248
Tunnel Interface Information:
Source interface: OUTSIDE IP address: Z.Z.Z.Z
Destination IP address: Y.Y.Y.Y
Mode: ipsec ipv4 IPsec profile: PROFILE_VPN_VTI
The remote site is AWS, i will ask to configure an IP address on the remote tunnel interface to see if this make any difference
Thanks for the information. I wonder if the issue might be related to the use of the 169.254 network. This network is a reserved network used for APIPA Automatic Private IP Addressing. I wonder if the behavior changes if you change the network to some other (not restricted) network?
Rick
Rick
As an experiment can you try to configure the static route pointing only to the virtual interface and see if you have the route redistributed then?
route VPN_VTI 172.23.40.0 255.255.255.0 Tunnel 50
Hello
I changed the subnet of the VTI interface but it doesnt seems to make any change, it is still not appearing on eigrp topology table or neighbors routing table
* 192.168.199.244, via VPN_VTI
ASA wont let me specify an outgoing interface, it needs a next hop address:
route VPN_VTI 172.23.40.0 255.255.255.0 ?
configure mode commands/options:
Hostname or A.B.C.D The address of the gateway by which the foreign network
is reached.
route VPN_VTI 172.23.40.0 255.255.255.0 Tunnel50
ERROR: % Invalid Hostname
Hello, it is ok. You are defining the outgoing interface at the begining :)
Put only this entry and see if it solves your problem.
BR
Cisco ASA wont let me configure static route command without a next hop
ERROR: % Incomplete command
I think maybe the problem is that i dont have all K values on a VTI interface to calculate EIGRP metric, but it has to happen with the tunnel interface subnet too
IP address 192.168.199.241, subnet mask 255.255.255.248
Source interface: OUTSIDE IP address: X.X.X.X
I added the 192.168.199.240/29 network to EIGRP process and it is advertised correctly
ASA:
P 192.168.199.240 255.255.255.248, 1 successors, FD is Inaccessible
via Connected (Infinity/0), VPN_VTI
ASA's Neighbor
P 192.168.199.240/29, 1 successors, FD is 25857
via Z.Z.Z.Z (25857/25601), GigabitEthernet0/0/1.102
I am running into the same issue doing a VTI with Azure. I got the VTI working and traffic passes just fine but I can't redistribute into EIGRP for my lan to connect.
For people new to VTI's. Keep in mind by default VTI's don't have crypto maps attached to them so you can't just turn on RRI and call it a day. I even called TAC directly and they are stump at the moment. They said they aren't sure if this is a feature allowed with VTI's at the moment but will have to escalate and reach back out to me.
This left me with two ideas I thought of.
1. do a static routes in my lan where I need it to get it working. I know this will fix my issue but I don't like it for the long term.
2. (This is something I want to try just to see if it is possible) Create a crypto map with that a random peer address but see if the ASA will allow me to leave all negotiations protocols blank. enable RRI and then do the pre-fix list and route map config like a standard RRI. I want to see if I can trick the firewall in a sense to inject the route into EIGRP but still ride the VTI.
I am trying to schedule some time to test this idea so I will follow up after. It could be a few days before I get to test it. Also if Cisco reaches out to me with a solution before this I will let you guys now.
Thanks for your reply. At last, i modified the VPN type to Policy Based and activated RRI acomplishing the route redistribution. This was not the ideal escenario because on the back up site, even if the VPN is down i get the route redistributed,
You can still acomplish this by configuring a Policy based VPN with the interface IP in one line of the Encryption Domain, configuring IP SLA and Tracking a route but you need a host on the remote side that you can reach. It is not as simple as the thing we wanted to do, but still works.
Letme know if what are you trying to do worked for you!
Thanks for the update telling us how you got it to work. A well deserved +5 for this.
Rick
Probably a bit late now, but just in case anyone stumbles into this same problem... What I found was the tunnel interfaces on an ASA don't provide enough information for EIGRP to work out a metric to the next hop, so it declares the route inaccessible. There didn't seem to be a way to set things like bandwidth and delay directly on a tunnel unterface (at least in 9.12) so I set default metrics for redistribution globally:
router eigrp 1
default-metric 1000000 1 255 1 1500
network 10.80.9.1 255.255.255.255
passive-interface default
no passive-interface INSIDE
redistribute static route-map EXTERNAL_ROUTES
route T1 10.51.16.0 255.255.240.0 169.254.247.21 1
interface Tunnel1
nameif T1
ip address 169.254.247.22 255.255.255.252
tunnel destination 52*.*.*
tunnel protection ipsec profile CLOUD
FW# sh eigrp topology | i 10.51.
P 10.51.16.0 255.255.240.0, 1 successors, FD is 2816
 Never come across this issue before as we use cryptomaps on existing tunnels and the routes point to a physical interface which provides all the info EIGRP needs for metric calculation.
