ASA5505 & Cisco Router 3825 - Double NAT w/ Port Forward
Techi3Rebel
I have been brainstorming over this for a few days and need help. This is my Cisco LAB environment used for study but also in production for daily use. I am trying to setup a double-NAT network with just one IP from my ISP through the ASA & 3825 going to (2) end nodes and multiple ports for port forwarding. It is currently working but only as simple PAT and I cannot initiate FTP from the outside. I know some may suggest removing the router, but this is my study LAB and it's a bit unconventional for learning purposes. I attached the diagram and would really appreciate it if you could provide some pointers, tips, parts of the config. I have done quite a bit of reading on different forums but cannot seem to grasp the concept. Thank you…MK_Double_NAT.jpg
16 Replies 16
blau grana
Level 7
Level 7
Have you configured static port forward for FTP port?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hello, and thanks for replying. I know I will need different types of NAT but I'm uncertain on how to accomplish that. For instance, if I work with just port 2222 going to my NAS at 192.168.1.60, at the ASA, do I create a static NAT from 24.x.x.x to a (made up) IP of 10.1.1.60, and then at the Router, do I take that 10.1.1.60 and static NAT to 192.168.1.60?
Does that make sense? Do I have to perform the same type of static NAT for all destinations and ports and also have a dynamic NAT pool for the PAT?
As you wrote, it is one way how to accomplish that -> you have to configure static portforward on both ASA and 3845.
Or you can perform NAT only on ASA, so you configure port forward -> 24.x.x.x 21 192.168.1.x 21. But make sure that ASA has a route to 192.168.1.0/24 network.
You have to choose one of this possibilities and perform static portforward for each service which you want to have reachable from internet. Additionaly you have to configure PAT for LAN host to be able to access internet.
Best Regards
Sorry that it took me so long to reply but I finally had time to play with this. I took your suggestion but I'm still not doing something correctly.
This is the error in the log:
Failed to locate egress interface for TCP from inside:10.1.1.1/16362 to 24.xx.xx.xx/2222
Please take a look at the following config from the ASA;
FF(config)# sho run object
object network DNAT_3825
object network INTERNAL_LAN
subnet 10.1.1.0 255.255.255.224
object network NAS_SFTP
host 192.168.1.60
description NAS SFTP - Port 2222
object service PORT_2222
service tcp source eq 2222 destination eq 2222
FF(config)# sho run nat
nat (inside,outside) static interface no-proxy-arp service tcp 2222 2222
nat (inside,outside) after-auto source dynamic any interface dns
FF(config)# sho run access-list
access-list ACL-OUTSIDE extended permit tcp any host 192.168.1.60 eq 2222
access-list ACL-OUTSIDE extended deny ip any any log
access-list ACL-INSIDE extended permit ip any any log
FF(config)# sho run access-group
access-group ACL-OUTSIDE in interface outside
access-group ACL-INSIDE in interface inside
have you got a route for 24.x.x.x.x on the ASA ?
Alain
Thanks for the response, here is the 'Sho Route'
Gateway of last resort is 24.xx.xx.xx to network 0.0.0.0
O    172.16.1.0 255.255.255.240 [110/11] via 10.1.1.1, 252:25:32, inside
C    24.xx.xx.xx 255.255.240.0 is directly connected, outside
C    10.1.1.0 255.255.255.224 is directly connected, inside
O    192.168.1.0 255.255.255.192 [110/11] via 10.1.1.1, 252:25:32, inside
d*   0.0.0.0 0.0.0.0 [1/0] via 24.xx.xx.xx, outside
The error message:
Is this from the ASA or the 3825?  Have you tried just setting up a single NAT statement on both the ASA and 3825? Also double check the routing table on the 3825 to make sure every route is visible.
That error is on the ASA. I am certain that my NAT is not correct and I posted the configs for both, the ASA and 3825 as well as the 'sho route'. Thanks for your help...
Configuration which you provided seems OK, but error message looks weird. Do you perform NAT only on ASA or do you perform double NAT?
If you perform NAT only on ASA, can you provide entire config and these outputs?
- ping 192.168.1.60
- packet-tracer input outside tcp REMOTE HIGH_PORT 192.168.1.60. 22222 detailed
REMOTE - replace with IP from which you are trying to reach 192.168.1.60 (some public IP)
HIGH_PORT - replace with some high port f.e 26154
- show conn and show xlate - when you try to reach 192.168.1.60
- show route
- please verify that you can reach internet from ASA, ping next-hop, 8.8.8.8
!!!!! please do not hide public IPs like 24.x.x.x, either replace them with other IPs or make sure that hidden IPs are represented with same signs, thanks !!!!!
If you perform double NAT, can you also provide config of 3825 router?
Best Regards
I am performing NAT on the ASA and on the 3825; ISP -> ASA 10.1.1.0/27 -> Router 192.168.1.0/26
- Ping from ASA to ASA5505 & Cisco Router 3825 - Double NAT w/ Port Forward192.168.1.60ASA5505 & Cisco Router 3825 - Double NAT w/ Port Forward does not work, another issue, here's the ASA log as it scrolls;
  • Denied ICMP type=0, code=0 from 10.1.1.1 on interface inside
  • Denied ICMP type=0, from laddr 10.1.1.1 on interface inside to 10.1.1.30: no matching session
  • Built inbound ICMP connection for faddr 10.1.1.1/0 gaddr 10.1.1.30/29878 laddr 10.1.1.30/29878
  • Built outbound ICMP connection for faddr 192.168.1.60/0 gaddr 10.1.1.30/29878 laddr 10.1.1.30/29878
  • Built local-host inside:192.168.1.60
- FF# packet-tracer input outside tcp 8.8.8.8 26154 192.168.1.60 22222 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xcb14fb28, priority=1, domain=permit, deny=false
        hits=78854759, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=outside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.1.0     255.255.255.192 inside
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: DROP
Config:
access-group ACL-OUTSIDE-IN in interface outside
access-list ACL-OUTSIDE-IN extended deny ip any any log
in  id=0xcad35bd0, priority=13, domain=permit, deny=true
        hits=821, user_data=0xc9187dd0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0 dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
      Running these commands resulted in very long outputs with no reference  to 192.168.1.60 when initiating an SFTP connection from 'outside'.
- FF# sho route
Gateway of last resort is 24.120.120.1 to network 0.0.0.0
O    172.16.1.0 255.255.255.240 [110/11] via 10.1.1.1, 290:33:34, inside
C    24.120.120.0 255.255.240.0 is directly connected, outside
O    192.168.1.0 255.255.255.192 [110/11] via 10.1.1.1, 290:33:34, inside
d*   0.0.0.0 0.0.0.0 [1/0] via 24.120.120.1, outside
      I cannot ping internally or externally from the ASA but I do have  internet connection as the ASA is currently connected and I have no  connectivity issues.
- I am not really certain  what you meant by hiding the public IP and the different signs so I just  manipulated the public IP's. I am including the config for the ASA and  the 3825 below, thanks again for your help and please let me know what  else I need to provide...
ASA Version 9.0(2)
hostname FF
enable password 4.x70RVTq0ba.OJq encrypted
xlate per-session permit tcp any4 any4
xlate per-session permit tcp any4 any6
xlate per-session permit tcp any6 any4
xlate per-session permit tcp any6 any6
xlate per-session permit udp any4 any4 eq domain
xlate per-session permit udp any4 any6 eq domain
xlate per-session permit udp any6 any4 eq domain
xlate per-session permit udp any6 any6 eq domain
passwd 1KFQnaNQdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 5
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan5
mac-address 001c.71a5.fa40
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan10
nameif inside
security-level 100
ip address 10.1.1.30 255.255.255.224
boot system disk0:/asa902-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 198.153.192.40
name-server 198.153.194.40
host 192.168.1.60
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list ACL-OUTSIDE-IN extended permit tcp any object NAS_SFTP eq 2222 log
access-list ACL-INSIDE-IN extended permit ip any any log
access-list ACL-INSIDE-IN extended permit icmp any any echo-reply log
access-list ACL-INSIDE-IN extended permit icmp any any echo log
access-list ACL-INSIDE-IN extended permit icmp any any log
access-list ACL-INSIDE-OUT extended permit icmp any any echo-reply log
access-list ACL-INSIDE-OUT extended permit icmp any any echo log
access-list ACL-INSIDE-OUT extended permit icmp any any log
pager lines 24
logging enable
logging asdm debugging
mtu outside 1500
mtu inside 1500
ip verify reverse-path interface outside
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
icmp permit any inside
asdm image disk0:/asdm-712.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group ACL-INSIDE-IN in interface inside
access-group ACL-INSIDE-OUT out interface inside
router ospf 1
network 10.1.1.0 255.255.255.224 area 0
network 192.168.1.0 255.255.255.192 area 0
log-adj-changes
default-information originate always metric 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http server idle-timeout 60
http server session-timeout 90
http 192.168.1.0 255.255.255.192 inside
http 10.1.1.0 255.255.255.224 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 192.168.1.0 255.255.255.192 inside
ssh timeout 60
ssh version 2
console timeout 0
dhcp-client client-id interface outside
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 10.1.1.1 source inside
ntp server 129.6.15.29 source outside prefer
webvpn
anyconnect-essentials
username cisco password vAf1q1H.ah.rqbDS encrypted privilege 15
username lab password n/pkFOGPjV0mLSxt encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
hpm topN enable
Cryptochecksum:1271f9da71948856f63e44e7268f48fa
: end
__________________________________________________________________________________
Cisco Router 3825
version 15.1
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname RR
boot-start-marker
boot system flash:c3825-adventerprisek9_ivs-mz.151-4.M6.bin
boot-end-marker
security authentication failure rate 3 log
logging buffered 51200
logging console critical
enable secret 4 1hdl2t2GTwuAChFnEIcCj0Iz7JBCJX01rwUvTaQTL7k
enable password 7 1057990D5505120F0801
no aaa new-model
clock timezone CST -6 0
dot11 syslog
no ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.4
ip dhcp excluded-address 192.168.1.51 192.168.1.62
ip dhcp excluded-address 172.16.1.1
ip dhcp excluded-address 172.16.1.14
ip dhcp pool DHCP_192.168.1.0/26
dns-server 192.168.1.1
default-router 192.168.1.1
domain-name ciscolab.local
ip dhcp pool VOICE_LAN
import all
network 172.16.1.0 255.255.255.240
default-router 172.16.1.1
option 150 ip 172.16.1.1
no ip bootp server
ip domain name ciscolab.local
ip name-server 198.153.192.40
ip name-server 198.153.194.40
ip inspect log drop-pkt
ip inspect tcp reassembly queue length 128
ip inspect tcp reassembly timeout 10
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
parameter-map type ooo global
tcp reassembly queue length 64
tcp reassembly memory limit 4096
tcp reassembly alarm off
voice-card 0
voice service voip
ip address trusted list
ipv4 64.237.39.42
ipv4 64.237.39.30
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
redirect ip2ip
sip
bind control source-interface GigabitEthernet0/1.20
bind media source-interface GigabitEthernet0/1.20
session transport tcp
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 172.16.1.1 port 5060
max-dn 25
max-pool 25
load 7960-7940 P0S3-8-12-00
authenticate register
tftp-path flash:
create profile sync 0020174213302002
voice register dn 1
number 1001
name EXT1
label EXT1
voice register dn 2
number 1002
name EXT2
label EXT2
voice register pool 1
id mac 000F.BA70.EABD
type 7960
number 1 dn 1
username EXT1 password 1234
voice register pool 2
id mac 000C.AC60.EC61
type 7960
number 1 dn 2
username EXT2 password 1234
crypto pki trustpoint TP-self-signed-2466671023
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2466671023
revocation-check none
rsakeypair TP-self-signed-2466671023
crypto pki certificate chain TP-self-signed-2466671023
certificate self-signed 01
license udi pid CISCO3825 sn FTI1017A0NT
archive
log config
hidekeys
username cisco privilege 15 password 7 0701282A1E1D310F12
username lab privilege 15 password 7 071111581C1B1A041317
redundancy
ip tcp synwait-time 10
interface Loopback0
description $FW_INSIDE$
ip address 99.99.99.99 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description OUTSIDE TO ASA$ETH-WAN$
ip address 10.1.1.1 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in max-reassemblies 64
duplex auto
speed auto
media-type rj45
no mop enabled
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.10
description DATA_VLAN$ETH-LAN$
encapsulation dot1Q 10
ip address 192.168.1.1 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
ip tcp adjust-mss 1460
description VOICE_VLAN$ETH-LAN$
encapsulation dot1Q 20
ip address 172.16.1.1 255.255.255.240
ip flow ingress
ip flow egress
router ospf 1
network 10.1.1.0 0.0.0.31 area 0
network 172.16.1.0 0.0.0.15 area 0
network 192.168.1.0 0.0.0.63 area 0
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat pool DHCP_192.168.1.0/26 192.168.1.1 192.168.1.62 netmask 255.255.255.192
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_GRE
remark CCP_ACL Category=1
permit gre any any
ip access-list extended SDM_OSPF
permit ospf any any
logging trap debugging
logging 192.168.1.60
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.63
tftp-server flash:/P0S3-8-12-00/P0S3-8-12-00.loads alias P0S3-8-12-00.loads
tftp-server flash:/P0S3-8-12-00/P0S3-8-12-00.sb2 alias P0S3-8-12-00.sb2
tftp-server flash:/P0S3-8-12-00/P003-8-12-00.bin alias P003-8-12-00.bin
tftp-server flash:/P0S3-8-12-00/P003-8-12-00.sbn alias P003-8-12-00.sbn
tftp-server flash:/SIP/SEP000DBC80EABD.cnf alias SEP000DBC80EABD.cnf
tftp-server flash:/SIP/SEP000DBC80EB61.cnf alias SEP000DBC80EB61.cnf
tftp-server flash:/SIP/XMLDefault.cnf alias XMLDefault.cnf
control-plane
mgcp fax t38 ecm
mgcp profile default
sip-ua
credentials number 13141234123 username GV13141234123 password 7 14123B1F26140672742E37252140 realm GVGW
authentication username GV13141234123 password 7 021E11674B2C56714A4A191A56
registrar dns:gvgw3.simonics.com:5070 expires 1800 tcp
sip-server dns:gvgw3.simonics.com:5070
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
pin 0000 override
max-dn 25
ip source-address 172.16.1.1 port 2000
max-redirect 5
system message ciscolab
cnf-file location flash:
max-conferences 12 gain -6
web admin system name cisco secret 5 $0$LEFH$00Kx0vw4FlNCZvO2KypRh.
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 14 2013 02:39:02
line con 0
exec-timeout 0 0
password 7 067366111F5A581710
logging synchronous
line aux 0
line vty 0 4
access-class 102 in
exec-timeout 0 0
privilege level 15
password 7 10400F005501131509
login local
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server time.nist.gov prefer
end
You are missing three things:
- static port forward on 3825
ip nat inside source static tcp 192.168.1.60 23 10.1.1.1 2222 extendable
- correctly configured NAS_SFTP on ASA
host 10.1.1.1
! remember, server is behind NAT, so ASA knows this server as 10.1.1.1
- allow traffic in ACL
access-list ACL-INSIDE-OUT extended permit tcp any object NAS_SFTP eq 2222
Best Regards
I ran the 3 commands on the specified device but I am still receiving the following error in the ASA and I cannot connect;
6May 14 201306:57:51
10.1.1.19156
Failed to locate egress interface for TCP from inside:10.1.1.1/9156 to 24.120.120.229/2222
This is the output from the ASA. Nothing else changed aside from the 3 lines you suggested, thank you...
- FF# packet-tracer input outside tcp 8.8.8.8 26154 192.168.1.60 2222 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
        hits=80158375, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: DROP
Config:
        hits=1093, user_data=0xc9187dd0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
You are mixing two approaches together. Either you configure single NAT on ASA or you configure double NAT, one on ASA and second on 3845.
You said that you chose second approach to perform double NAT. It means that 192.168.1.0/26 should be hidden behind 10.1.1.1 IP, but I can see OSPF routes for both 192.168.1.0/26 and 172.16.1.0/28 in ASA routing table. You have to choose on approach and stick with it!
So please choose which way you want to continue and in meantime please upload output of:
FF# packet-tracer input outside tcp 8.8.8.8 26154 10.1.1.1 2222
Best Regards
I don't mind keeping the 192.168.1.0/26 route and just getting this to work. I did remove that route but still nothing. This is the result in the ASDM log;
w/o network 192.168.1.0 255.255.255.192 area 0 - Failed to locate egress interface for TCP from inside:10.1.1.1/18470 to 24.120.120.229/2222
w/ network 192.168.1.0 255.255.255.192 area 0 - Failed to locate egress interface for TCP from inside:10.1.1.1/18523 to 24.120.120.229/2222
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.1.1.0        255.255.255.224 inside
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group ACL-INSIDE-IN out interface inside
Phase: 7
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-status: up
output-status: up
Action: drop
