ASA5505 & Cisco Router 3825 - Double NAT w/ Port Forward
Techi3Rebel
I have been brainstorming over this for a few days and need help. This is my Cisco LAB environment used for study but also in production for daily use. I am trying to setup a double-NAT network with just one IP from my ISP through the ASA & 3825 going to (2) end nodes and multiple ports for port forwarding. It is currently working but only as simple PAT and I cannot initiate FTP from the outside. I know some may suggest removing the router, but this is my study LAB and it's a bit unconventional for learning purposes. I attached the diagram and would really appreciate it if you could provide some pointers, tips, parts of the config. I have done quite a bit of reading on different forums but cannot seem to grasp the concept. Thank you…MK_Double_NAT.jpg
16 Replies 16
Did you get this resolved. I think I have a simular problem in that I have an internal webserver that tries to send its responses to the original external source address rather than the LAN address of our ASA. Because we dont have any default routes on our core switches though the packets are just dropped rather than sent to the internal LAN of the ASA.
stevenmcconnell
I have double NAT running and working great, here is pretty much my running config from my Router 2821 and ASA 5505.
My setup.
ISP ----> 2821 -----> ASA5505 ------> FTP Server
CISCO ROUTER 2821;            Gi0/0 (ISP)        Gi0/1 (10.10.10.1)
interface GigabitEthernet0/1
description LAN-Internal
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex full
speed 100
ip nat inside source static tcp 192.168.1.6 21 interface GigabitEthernet0/0 21
S     192.168.1.0/24 [1/0] via 10.10.10.5
CiSCO ASA 5505 (routed mode)        (eth0/0) 10.10.10.5    (eth0/1) 192.168.1.1
(eth0/1)
interface Vlan1
nameif inside
security-level 100
(eth0/0)
interface Vlan11
description OutsideConnection
nameif outside
security-level 0
ip address 10.10.10.5 255.255.255.0
object network FTPSERVER
host 192.168.1.6
access-list outside_access_in extended permit tcp any object FTPSERVER eq ftp log debugging
object network FTP
nat (inside,outside) static FTPSERVER service tcp ftp ftp
CISCO 2960 Layer 2 only with several Vlans
FTP SERVER
